Need recommendations and advice for gaming computer build - 1400 CAD budget
Vizions
14
I am currently planning on building a computer for gaming purposes. I plan on playing World of Warcraft, League of Legends, BF4 and Farcry. Idealy i'd like to play the first 2 on maximum settings with 60+ Fps at all times, and the 2 latter with the best i can get from a budget of 1300-1400 dollars canadian, though the latter arent as important to me..
I am really new to building computers so i'd like any reccomendations and corrections to my build as i am not entirely confident that all these components can work correctly together, if possible i'd like some case reccomendations as im not entirely sure which cases can hold all these components.
Additionally, i was wondering, is it possible for me to build this computer and only use a SSD? as well as not use a CD rom drive.
Current build is as follows:
Motherboard: ASRock Z170M PRO4S Intel Skylake LGA1151 ATX PCI-EX1 HDMI/DVI USB3.0X8 1XULTRA M.2 Motherboard - Cost: 144.00
CPU: Intel Boxed Core I5-6600K 3.50 GHz, 6 M Processor Cache 6 for LGA 1151 - cost: 340.39
Video card: EVGA GeForce GTX 970 4GB SC GAMING ACX 2.0, 26% Cooler and 36% Quieter Cooling Graphics Card 04G-P4-2974-KR - Cost: 464.00
PSU: Corsair CX Series 750 Watt ATX/EPS Modular 80 Plus Bronze ATX12V/EPS12V 744 Power Supply (CX750M) - Cost: 101.89
RAM: CORSAIR Vengeance LPX 16GB (2 x 8GB) DDR4 DRAM 3000MHz C15 memory kit for DDR4 - Cost: 144.62
Cooling system: Cooler Master Hyper 212 EVO-CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2) - Cost:48.50
SSD: Samsung 850 EVO 250GB 2.5-Inch SATA III Internal SSD (MZ-75E250B/AM)
Total cost: 1,365.93
Approximate Purchase Date: 30-40 days from now
Budget Range: 1400 CAD before shipping
System Usage from Most to Least Important: Gaming, streaming, recording , editing, surfing
Are you buying a monitor: No
Parts to Upgrade: Open to suggestions
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Currently using amazon however open to advice and reccomendations
Parts Preferences: none
Overclocking: Most likely, however it isnt a necessity
SLI or Crossfire: maybe
Your Monitor Resolution: 1920x1080
Additional Comments: ideally a quiet running system that can be upgraded easily in future.
PCPartPicker part list: http://ca.pcpartpicker.com/p/scbFBm
Price breakdown by merchant: http://ca.pcpartpicker.com/p/scbFBm/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($271.25 @ Vuugo)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler
Motherboard: Gigabyte GA-H170M-D3H Micro ATX LGA1151 Motherboard ($115.00 @ Vuugo)
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR4-2400 Memory ($94.99 @ Newegg Canada)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($115.98 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($67.95 @ shopRBC)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($79.99 @ NCIX)
Total: $745.16
Prices include...
Total: $745.16
Generated by PCPartPicker 2016-03-11 03:15 EST-0500
if your not going to over clock or sli save some money go with micro atx mb and a locked cpu. use the savings for a hard drive. (ssd have limited writes so your better off using a hd for holding music and downloads).
cx power supply not a good unit. there no gpu has the newer pascal are dropping in june.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($333.25 @ Vuugo)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($40.25 @ Vuugo)
Motherboard: Gigabyte GA-Z170MX-Gaming 5 Micro ATX LGA1151 Motherboard ($179.00 @ Vuugo)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($84.74 @ DirectCanada)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card ($439.25 @ Vuugo)
Case: NZXT S340 (Black) ATX Mid Tower Case ($98.05 @ Vuugo)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply ($99.99 @ NCIX)
Total: $1390.51
Generated by PCPartPicker 2016-03-11 03:17 EST-0500
this should suit your really well.
you can buy os cheap online from it stores that are not listed on pc aprt picker.
its a shame u cant buy a cryorig h7 in cana this topic has been before🙁 whyyy canadaaaaaa
How will downgrading ( I assume?) to the i5 6500 affect overall performance and future upgrades?
additionally, with that build would you recommend I keep the 970? or maybe go for something like the r290, i assume the new pascal from nvdia will generally cost more.
You play old games that don't need a GTX 970. If you're trying to build on a budget, I would get something else. The GTX 970 is still pricey right now. If you were playing something like The Division that just came out I would say otherwise.
As far as video cards go...this is one of the best sites to start doing research : The "Common Video Card Chart" is very useful.
http://www.videocardbenchmark.net/
The main reason I am looking at the 970 is because I'd like to have the option to play these newer games later on with decent quality, its just the games i play mostly are the ones i put in the original post in order of most played to least.
youre right and wrong my friend.
right: yes its expensive.
wrong: the gtx 970 is todays card best bang for the buck(performance/price wise).
for the games he mentioned: battlefield 4 and farcry 4 the gtx 970 allows him to play on ultra.
Ok I just did a little more research real quick I'll agree with you it Is good for the price since you can snag one up for around $320.00...I was going by the price you quoted from some site I never heard of, which is way way over what you should pay.
GTX 970 seems like a winner to me.
