Need Recovery Disk Toshiba Satellite M645-S4070
Jul 12, 2018
Does someone have a working Recovery Disk for a Toshiba Satellite M645-S4070 Computer? Recovery Disk needs to be for Windows 7 64 bit.
Additional Specs:
Intel Core i5 CPU, M460 @ 2.53 GHz, RAM 4 GB, 500 Gb HD
I appreciate any assistance the community can provide.
Thanks,
David
Hi Phillip,
Thank you for your response. I tried it out and unfortunately the webpage is not working correctly.
It won't accept the serial number when entered.
However, I found on a different page, that recovery media can be created by selecting "create recovery media" in the start menu. The DVD's wouldn't burn after disk 1 but I was able to use a blank 16Gb flash drive to copy the recovery media onto.
I also found on the website that I can start the OS and press the number zero "0" until the recovery environment is loaded. This is another way to restore the computer back to original factory settings.
Thanks for your assistance.
Hi Phillip,
