Need replacement for KT4VL
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
Mine is dying. Network adaptor died. Floppy doesn't work. DVD ROM is
flaky. What's good to use with XP2000 processor?
Are you sure that it is m/b problem?
"Oliver Costich" <olc-caNOSPAM@comcast.net> wrote in message
news:i8t641tah5lukgkl3ej7gqjk3p9seqst7i@4ax.com...
Remove and replace the battery before you do anything else. You will
have to go into the bios and set everything because it will load the
defaults. Do not even bother to check the battery just r&r. Very
unusual to have this many things not work unless the board encountered a
power line spike or battery flaky (poor contact in socket and the like)
