Need Serious Help b/w Amd fx 8350 and Intel 4460!!!
Kunalsehgal
41
Guys, am very much frustrated b/w these two processors. I searched a lot and found that Amd fx 8350 is better for video rendering and video editing where intel i5 4460 is better for gaming. I need a processor for video editing, i should choose Amd but Amd doesn't come with integrated graphics like intel. Currently i have no budget to buy a new graphic card but i will buy it after one month or two. That means i need to buy intel to run pc for months but intel is not good for video editing. So what should i do???
Oh my god think about this. If you were gaming, you would need a dedicated GPU, and even if the Intel one did come with a GPU, it is only good for web browsing, it WILL NOT GAME FOR YOU. So the idea is to get a processor and a video card at the same time. It really doesn't matter if it comes with an igpu. And also you need a good board for the fx 8350, it draws a lot of power. I'm curious, do you know what you are doing? I used my friends rig for a video rendering project and a video took 2-3 days to render, I mean getting a Xeon isn't all to shabby for you either. Either way, anything like rendering and gaming REQIRES a dedicated GPU.
I wanna say that If i use amd then i will not be able to install windows or minimal work as there will be no integrated graphic card on the processor and i will buy my graphic card after 1 month or more. So what should i do???!!! :3
Buy the i5 4460. You clearly need an iGPU so there's not point in considering the AMD proccy. Unless you can wait for like, a month, until you buy a GPU. If you can wait, then it's a simple decision - Buy the AMD CPU. It's really not complicated: If you CAN'T wait until you buy a GPU, you need to get the i5. If you CAN wait, get the 8350.
It really is as simple as that.
