Need small cpu fan
Aug 1, 2018
7
Im just gonna get to the point. Small case (link for dimensions https://www.newegg.com/Product/Product.aspx?Item=N82E16811235053&cm_re=Zalman_-_T2_Plus_MicroATX_Mini_Tower_Case-_-11-235-053-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=11552995&PID=7899552&SID= ) Planning on getting a ryzen 7 2700 and overclocking it to 3.7-4.1GHz, I have a ASRock AB350M Pro4 (AM4 socket) My budget is $50, I appreciate any help thanks.
cin19
The ryzen 2700 will come with a cooler, it is pretty good, so you don't need to buy other one. But if you want to buy one, may consider this CRYORIG C7 for $30. https://www.newegg.com/Product/Product.aspx?Item=9SIA4UF39D5213 And you can ge the free AM4 mounting kit for free. http://www.cryorig.com/getam4.php#applyam4
And one more, you may need the cpu for update the BIOS on the b350 too, more info and get the free cpu to update the BIOS too. https://support.amd.com/en-us/kb-articles/Pages/2Gen-Ryzen-AM4-System-Bootup.aspx
Similar threads
