Need some advice for Upgrading my PC with F2A58M-HD2 (P0)
Feb 26, 2018
4
Hello i think it's time to upgrade my current system bought back in 2014.
Im not in the mood of buying a new system. My requirements  are not huge but i want
to be able to play some more games. (Like GTA V with low or medium settings but to be playable)
My current specs:
AMD Athlon X4 750K
F2A58M-HD2
8,00GB RAM Single-Channel DDR3 @ 806MHz
2048MB ATI AMD Radeon R7 200 Series (ATI) (240D)
After some search i found these:
EVGA 600W (Need new power supply now i have a 500W Chinese very weak)
AMD Athlon X4-880K Box
Palit GeForce GTX750 Ti 2GB StormX Dual OC (NE5X75TT1341F)
What do you think? First of all is my system compatible with all of these?
(Can this graphics card fit in this motherboard?)
Will i be able to run some games with some respectable fps?
That is about your only choice for CPU. Don't know what the relative cost of an 860K vs 880K. Your motherboard has an 8 pin CPU power plug. It might support some overclock. The 880K is newer generation hardware so will require less power.
GPUs are difficult depending on what is available at a decent price. The 750ti is three generations old but should be OK.
You may still get stuttering because of your RAM. I don't know if the RAM upgrade would be better than the GPU upgrade.
Ok. Do you think its gonna be a good update? Gonna see some difference?
