Need some Advice
ZeroCold
8
Hello till now I was with I5 3470 cpu blow up and now I have to replace it with new one, and now I decide to buy I5 4690k with GIGABYTE Z97P-D3 I know there is better motherboards but I cant afford more now so my question is with this motherboard can i overclock this cpu in future not now and I don't want some big numbers here and next question my GPU is EVGA GTX 970 SC i have 2x 8 GB kingston 1600mhz and 120GB SSD Kingston Hyper X my old pc works with 600W psu will I need a new one or the whole system will work fine thank you and sorry for bad English.
you going nowhere with the GIGABYTE Z97P-D3 , even if is a Z97 mobo...its not well built for overclocking , because bad vrm heatsink and not enough vrm phases
i suggest you an asrock Z97 extreme3 , really cheap and very well built
i suggest a good psu , i do not know which psu you have but usually a good one is
seasonic/xfx/antec hcg/evga B2-G2/rosewill capstone
Hello,
All Z97 motherboards are made with overclocking in mind, but some are better than others 😀
If you don't want to break any CPU speed records, that Gigabyte will be OK (it will do 4 GHz, no worries, just be sure you have a good CPU cooler). BUT, don't try to overclock a system running a PSU such Delux, JNC, RPC (etc, etc...), you risk to lose the entire system.
I will not OC atm maby after couple of monts when I buy another PSU but will this PSU work normal with asrock Z97 extreme3 + i5 4690k + 16 GB ram + EVGA GTX 970 SC without OC like I sayd atm I cant spend more money and I have to wait 1-2 monts until take new one
