Hey guys,
First timer here, usually able to work things out and sort things myself but needing opinions on this. I use my PC primarily for streaming video games and right now its fine, most games I can stream perfectly fine and I used to be able to stream Siege & PUBG perfect as well. However now when I stream them, I drop frames and discord starts lagging, which I know is mainly my CPU.
I stream with OBS Studio using Hardware Encoding, so it uses my GPU not my CPU.
Main question, with the specs i've listed below, what should I upgrade first?
MOBO: ASROCK H81M - HDS
CPU: Intel Core - i5-4440 @3.10Ghz
RAM: G.Skill Ares 8GB (2x4GB) (1888Mhz)
GPU: GTX 780 Dual Classified AXC
PSU: COrsair VS650
EDIT: To clarify, i am not dropping frames on my stream, my stream is outputing a constant FPS that i set (whether 30 or 60), it is IN GAME i am dropping frames.
PSU: COrsair VS650
