Need some help immediately!!!
Giwrgos_4
Commendable
Sep 30, 2016
43
Hello community,
I am going to build a new pc with the components below:
SSD:SAMSUNG 850 PRO 512GB
MOTHERBOARD: GIGABYTE Z270X-ULTRA GAMING
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor
RAM: Corsair Vengeance LED 16GB (2 x 8GB) DDR4-3000 Memory
CASE: Corsair Crystal 570X RGB ATX Mid Tower Case
PSU: Corsair 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply
GPU:MSI GeForce GTX1060 6GB
COOLING: Corsair H100i v2.
In addition,i will not overclock the CPU.
My question is:
Will i have issues with CPU temperature?
If i will,what can i change/do to prevent this?
Thanks in advance.
I don't think you will have any issues with temp. You will have a nice water cooler. For the people say 1000 w is to much. Who cares...
A 1000watt power supply is ridiculous overkill for that build. It's a waste of money and wont be anywhere near it's efficiency curve with the load your system will put on it.
An H100i is more than enough for a 7700k at stock clocks. I use a 30 dollar hyper 212 evo air cooler on my 7700k at stock and temps are fine.
Yeah but i want to build it once and for all :).
Maybe in the future 1000w will be needed who knows.
Really?Very glad to hear that cause i've read some articles on the web,which telling that ppl have problems with i7 and H100i
This coller is bad for this setup?And which one should i use?
Not that much.
In normal use you will actually be hurting the PSU because you won't be drawing enough power.
If you want to future proof get a 750W, but no more than that.
First time i hear something like this.
I'm confused now :)
They are simply saying you are spending money in the wrong places if your goal is gaming.
If you don't plan to overclock the CPU, or just a mild overclock, you can use a much cheaper and reliable cooling solution.
The money you are spending on a power supply can easily get you the next GPU up.
I would also say you are overspending on the motherboard.
Its not bad just way more than needed, as someone mentioned a Hyper 212 or a Cryorig would be a better option, and getting yourself a decent 550-650w PSU would save a good chunk of change without losing any performance, than you may be able to get a GTX 1070 get and better performance for the same amount of money.
Also Fan based coolers last longer and have less parts to go wrong, I have seen many cases of a water cooling pump dieing after a few years.
Power supplies are built for maximum efficiency between 50% and 80% load.
Running a 1000W PSU with maybe a 300W load on it won't really hurt it, but it will waste power, which is silly with something like a Platnum rated supply. It would be more efficient to get a 550W Gold supply for a single GPU system.
1000W is good for like 3 high end Nvidia GPUs (Or two AMD Vega's), or overclocking Threadripper or high core count i9 CPUs.
If the PSU draw isn't in the efficiency curve it's actually hard on the PSU.
I would get a 650W or 750W PSU and take that money you save and get a GTX 1070.
Thanks man i will reconsinder now :)
The reason i picked 1000w its because maybe in the future i will change some parts and i will need the watts.Will i have a problem with something as someone answered me?
I've heard that i7 cores are extremly good and for gaming 7700k is great.
My h80i failed recently, water leakage included. It ran for roughly 3 years continuous, likely exceeding the designed run time by quite a bit. Nothing damaged though, just put my old tuniq tower back on it after a thorough cleaning.
Also had pump housing failure on an asetek style all-in-one, but it didn't leak until I removed it. Plastic actually cracked, pretty sure that one was a pre-mature failure, but still out of warranty.
You can run that machine and with 2x GTX 1080's in SLI on a 750W PSU.
I could see an 1000W PSU if were building an 8 Core I9 System and OCing it with a GTX 1080Ti etc.
Heres a better build although the price of the 8700k is a bit high, and not sure what features you want with a motherboard (RGB or what not) Also great deal on that PSU currently.
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($399.89 @ B&H)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler ($34.89 @ OutletPC)
Motherboard: MSI - Z370 GAMING PLUS ATX LGA1151 Motherboard ($129.99 @ Amazon)
Memory: Corsair - Vengeance LED 16GB (2 x 8GB) DDR4-3000 Memory ($164.89 @ OutletPC)
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive ($233.88 @ OutletPC)
Video Card: MSI - GeForce GTX 1070 8GB Video Card ($399.99 @ Amazon)
Case: Corsair - Crystal 570X RGB ATX Mid Tower Case ($179.98 @ Amazon)
Power Supply: SeaSonic - FOCUS Plus Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($78.99 @ SuperBiiz)
Total: $1622.50
Generated by PCPartPicker 2017-10-11 11:15 EDT-0400
Try this, a nice six core CPU (Availability might be an issue) some wiggle room on the power supply, easily support for another GPU.
On the SSD, if you really want a Pro series Samsung, go for it, but for most people the 850 Evo is the best price/performance.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor ($199.88 @ OutletPC)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive ($169.88 @ OutletPC)
Video Card: MSI - GeForce GTX 1070 8GB Video Card ($449.99 @ Amazon)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Amazon)
Case Fan: Corsair - SP120 RGB High Performance 52.0 CFM 120mm Fan ($19.88 @ OutletPC)
Total: $1439.37
Generated by PCPartPicker 2017-10-11 11:17 EDT-0400
Can i fit in tis motherboard 8th generation CPU?Cause it says that it supports 6th/7th gen.
It still is and will be for awhile.
Not much difference between an I7 7700K and I7 8700K in gaming looking at the latest tests.
But if building new NOW I would go with a I7 8700K machine.
The Z370 motherboards are for 8th generation CPU's
