As stated in the title, im putting together a new build and have decided to go with the Ryzen 5700X chip (mostly because of advice on these forums and a current sale on newegg).
I'm really not a professional and will likely get some help, but I need some advice for a MB. A few things to keep in mind:
I will likely want to overclock my CPU.
I'm looking for ATX - this is my case which is rather big.
My budget is somewhere around or under $200.
I'm looking at spending a decent amount on a GPU (not fully decided what just yet, but i'm eyeing an RTX 3060 - my heart isn't set on it yet though)
I'm not sure about the actual differences with 3200 vs 3600 RAM, I'm looking to get most bang for my my buck but not cheap out either. Probably gonna be going 2x16gb.
I currently am using this old SSD on my current build with windows 10 installed (this might be another question, but im looking to just use that SSD and buy another one for more storage)
I'm also looking at moving over my current 750w PSU to the new build. (not sure if there'll be any compatibility issue there - again that might be another question)
The MB im looking at getting
This seems to be what im looking for, but im not 100% married to it if reasons are given for anything else. Like i said, i probably missed something and i dont know exactly what I'm doing (I havent put together a build in 10 years).
Thanks in advance for the help!
