Parts:
AMD Ryzen 7 2700x
MSI B450 Gaming pro carbon ac atx am4 motherboard
G skill triden z rgb 16gb ddr4-3200 memory
western digital blue 500gb m.2-2280 ssd
seagate barracuda 2tb hdd
evga GeForce rtx 2080 black video card
nzxt - h500 atx mid tower case
evga - super nova g3 650w 80+ gold certified fully-modular atx power supply
monitor- viewsonic xg2402 24" 144hz monitor
Ill try to explain what happened step by step. I put the motherboard on top of the box it came in. I installed the CPU as well as the cooler it came with. I installed the RAM in the slots they were recommended. I tested the parts to see if they worked, by jumping the power switch with a a screwdriver and everything lit up and the fans from the CPU and PSU were spinning. Next I tried testing the parts with the GPU as well as connecting the GPU to a monitor. Everything lit up like before the fans were spinning but I got no signal on the monitor and after like 10-20 seconds everything shut down. I tried to jump the board again but nothing happened. I removed the GPU and tried powering the motherboard on but nothing happened. I tested the PSU with the 24pin connector and the fans spin so I think the PSU is fine. Not sure what to do at this point.
AMD Ryzen 7 2700x
