Need some help with cpu
james1994
12
Will the amd x4 760k bottleneck the r9 270x 2gb oc edition? If so how bad will it be? My motherboard is msi a78m-e35 and Im running the r7 260x 2gb oc edition perfectly fine. my psu is 450w and ddr3 ram is 8gb
Vitric9
1,362
170
I think that the Athlon II 760K should be fine with that GPU. The Athlon II 760K is almost Identical to the FX 4350 aside from the L3 Cache and the type of MB it uses. Other than that the FX 4350 is roughly about 4%-8% faster. Also it uses the same micro architecture an the Vishera FX series CPUs code named Piledriver. And You can look this up. Dice paid upwards to $8 Million USD for Optimization for their CPUs especially the FX series. Often you will see the question "will my FX 4150 Bottleneck X graphics card" and for the R9 270X you should get pretty much all the performance you can expect.
