Need some help with my first gaming PC build ;)
yair8433
Hey, so i want to buy a $1,300 gaming computer, the purpose of the PC is to run all games for the next 4 years on High/Ultra/Medium settings on 1080p. Please tell me if all good with this build and all will work for the next 4 years at those settings on ALL games, And no, i'm not going to overclock the CPU... Maybe the GPU --- Build:
CPU - intel i7 7700K
CPU Cooler - Corsair H60
GPU - Gigabyte GeForce GTX1070 G1
Mobo - Gigabyte Z270X-Ultra Gaming
RAM - 16G (2x8G) Corsair Vengance LPX DDR4 3000Mhz
SSD - Samsung 850 EVO 500GB
Case - Fractal Design Define R5
PSU - FSP 600W Aurum S 80+ Gold
I know this is a $140 more than what your original budget is but if you can squeeze a bit more you can try and get this. (im assuming you are in the USA)
PCPartPicker part list: https://pcpartpicker.com/list/8BwsPs
Price breakdown by merchant: https://pcpartpicker.com/list/8BwsPs/by_merchant/
CPU: Intel Core i7-7700 3.6GHz Quad-Core Processor ($314.99 @ Newegg)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler ($64.99 @ Newegg)
Motherboard: Asus STRIX H270F GAMING ATX LGA1151 Motherboard ($143.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($104.99 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Newegg)
Video Card: EVGA GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card ($604.98 @ Newegg)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case ($99.99 @ Newegg)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply ($55.99 @ Newegg)
Total: $1439.90
Generated by PCPartPicker 2017-02-23
for a extra $140 you could get a gtx 1080, since you wont be overclocking i went with a non K version, i was going to put 7600 as a recommendation but maybe soon games would really benefit having 4C/8T. and a gtx 1080 would probably do good for your 4 year run. a h270 board since you wont be overclocking so you cut off budget there and send it to the PSU. I went as far as recommend a smaller SSD and a 1TB storage drive. i think its clear what im trying to pull off there.
