[SOLVED] Need some help with my HP Compac 6200 Pro
Mar 11, 2020
8
All I want, is the best GPU I can upgrade to without blowing my power supply up. Your help is greatly appreciated. Thanks!!!
Specs
320W Power Supply
HP Compac 6200 Pro MT PC
x64
Windows 7
i5 2400 3.10GHZ
8gbs of Ram
That ones no longer available. What about this?
EVGA NVIDIA GeForce GTX460 1GB Video Card 01G-P3-1373-TR PCI-Express
No. At that point, you'd be better of investing in a Ryzen 2400G or 3400G with their Vega 11 Igpu which would yield relatively the same performance as the GTX 460: https://www.techpowerup.com/gpu-specs/geforce-gtx-460.c265
As for the psu recommendation: It's a generalized recommendation based on an estimate.
It's entirely possible to get away with less, if the unit in question is actually up to the task.
What do you mean by 'proper PCI bracket'?
There are low profile models of those cards - unless you meant something else?
PCIE 3.0 is backwards compatible with PCIE 2.0.
Oh never mind at first I was thinking it wouldn't properly fit. So since I'm legacy I can do either of the ones you suggested??
In this forum they say it needs a 450 watt power supply. Which would put me out of reach...
https://www.guru3d.com/articles-pages/geforce-gtx-460-review-(roundup),13.html
I'm not a hardcore gamer, I'll spend between 30 and 70ish at the very most. If I can run Far Cry 4 tier games I would be happy
