Need some ideas/help for a new build
Madmaxneo
335
I approached my boss at Uhaul and asked if Uhaul would sponsor a build. After some questions and pictures of my build he asked me to come up with a proposal.
I need some help in this build proposal because I am not quite sure what would be a decent setup for something they may be put on display at the front of the store or whatever they may do with it
My idea is build a system that has the same color scheme as a Uhaul truck. It would be all white (MB, case) with orange vinyl on the outside and some orange components and orange tubing (maybe UV tubing with UV lights added to the build) inside.
But I am not quite sure what is good nowadays as far as a MB manufacturer and CPU combo, the case should be easy. I plan on using a Swiftech AIO and painting it white (not the fins though) if I watercool at all. I am not sure what they would do with this build so I want to make maintenance easy if I go the watercooling route. I plan on two options for this proposal, one for lower end graphics and the other for a bit higher (thus more expensive) performance.
I have a Cricut machine for cutting out the vinyl and I have access to plenty of vinyl for this project.
I am not going to be picky on this build as far as Intel, AMD, nvidia, etc....
So far it is between this MSI board and this Asus board. Right now the MSI board is in the lead as the colors match the basic aluminum and white colors of a uhaul truck.
But now I need some decent RAM that is either orange in color or has it so I can remove the base heatsinks to change them out for orange heatsinks, if I can find some.
So ideas?
The only other orange memory i can find is this one, but it's DDR3...
https://www.gskill.com/en/product/f3-1333c9d-16gao
Those are nice but the black is a contrast to the color scheme I am looking for which is primarily white and orange (or an red-ish orange).
But do you know if there is anything that has more orange in it than that?
If you want to create masterpiece,
CPU: Intel - Core i7-7820X 3.6GHz 8-Core Processor ($574.99 @ Amazon)
Motherboard: Asus - PRIME X299-DELUXE ATX LGA2066 Motherboard ($463.04 @ Newegg Marketplace)
Memory: Corsair - Vengeance RGB 32GB (4 x 8GB) DDR4-2666 Memory ($349.99 @ Amazon)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive ($77.99 @ SuperBiiz)
Storage: MyDigitalSSD - BPX 256GB M.2-2280 Solid State Drive ($114.99 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G Video Card ($750.48 @ B&H)
Case: be quiet! - Dark Base Pro 900 /Window (White) ATX Full Tower Case ($269.00 @ SuperBiiz)
Power Supply: Corsair - RMx White 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($159.99 @ Newegg)
Other: EK-FB ASUS PRIME X299 RGB Monoblock - Nickel ($137.00)
Other: EK-XRES 140 Revo D5 PWM - Plexi (incl. sleeved pump) ($170.00)
Other: EK-CoolStream XE 360 (Triple) ($100.00)
Other: Fittings, Tubings, coolant etc ($100.00)
Total: $3267.47
Generated by PCPartPicker 2017-10-19 04:02 EDT-0400
Yeah, umm, I am pretty sure they will not approve that price...lol. I most definitely can't afford that so it's out, unless you want to send me the money?
It looks like I will have to go with different RAM heatsinks then. Either that or all white RAM and possibly the LED sets for the RAM. All depends on the cost.
OP you might like this H440 but I think it's modded:
Another option :
CPU: AMD - Ryzen 5 1600X 3.6GHz 6-Core Processor ($224.68 @ OutletPC)
CPU Cooler: Cooler Master - MasterLiquid Pro 120 66.7 CFM Liquid CPU Cooler ($70.19 @ Amazon)
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard ($103.98 @ Newegg)
Memory: GeIL - SUPER LUCE 16GB (2 x 8GB) DDR4-3000 Memory ($156.93 @ Newegg Marketplace)
Storage: Corsair - Force MP500 120GB M.2-2280 Solid State Drive ($74.99 @ Amazon)
Video Card: Asus - GeForce GTX 1060 3GB 3GB Dual Video Card ($222.88 @ OutletPC)
Case: NZXT - S340 (White) ATX Mid Tower Case ($64.99 @ SuperBiiz)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply ($32.98 @ Newegg)
Total: $951.62
Generated by PCPartPicker 2017-10-19 23:24 EDT-0400
U can paint the internal white parts inside the case orange and also paint the aio tube orange. Put a uhaul logo in the front face of the case.
Paint the heatspreaders of the ram orange. Even the thumb screws and stands of the case in orange would contrast nicely.
I like this idea! Except I would need to add more HDD space and I am still thinking the Swiftech CPU cooler.
I wish I had seen this before but I never received a notification that someone posted a response. Now the price has gone up $100. But this is good!
