Need someone to look over my watercooling parts I picked out so far
huntsman
887
Hello everyone!
I been doing some research and been putting together a list of parts that I will start ordering in the near future. Currently I have the obsidian 900d case coming in and the Asus crosshair V formula Z mobo. I am looking to go all out on this rig, a good performer and nice looking.
Just need some one to look over some of the parts i picked out for the watercooling. Things might change but I feel like I have compiled a pretty good list so far.
quick list of my specs atm
cpu - FX 8320 will be overclocking it obviously
ram - 8gb 1600mhz for now will get 16gb 2x8 sticks sooner or later
gpu - will be a 290x maybe even 2 of them
watercooling list
CPU BLOCK - Swiftech Apogee XL
http://www.frozencpu.com/products/24145/ex-blc-1725/Swiftech_Apogee_XL_Extreme_Performance_Universal_CPU_Waterblock_Intel_AMD.html?tl=g30c85s139#blank
PUMP - Swiftech MCP655 Variable Speed 12v Water Pump
http://www.frozencpu.com/products/16737/ex-pmp-203/Swiftech_MCP655_Variable_Speed_12v_Water_Pump_w_G14_Thread_Ports_Perfectly_Tapped.html?tl=g30c107s153#blank
RESERVOIR - Bitspower Water Tank Z-Multi 250 Inline Reservoir
http://www.frozencpu.com/products/14261/ex-res-319/Bitspower_Water_Tank_Z-Multi_250_Inline_Reservoir_-_Ice_Red_BP-WTZM250P-IRDBK.html?tl=g30c97s166
RADIATOR - Alphacool NexXxoS Monsta Quad 120mm Radiator
http://www.frozencpu.com/products/16237/ex-rad-412/Alphacool_NexXxoS_Monsta_Quad_120mm_Radiator_-_80mm_Thick.html?tl=g30c95s570#blank
MOBO BLOCK - EK ASUS Crosshair V Formula(-Z) Full Board Cooling Block Kit
http://www.frozencpu.com/products/17962/ex-blc-1390/EK_ASUS_Crosshair_V_Formula-Z_Full_Board_Cooling_Block_Kit_-_Acetal_Nickel_CSQ_EK-FB_ASUS_C5F-Z_-_AcetalNickel.html#blank
RAM - EK Monarch Series X4 Ram Liquid Cooling Block and EK RAM Monarch DIMM Module
http://www.frozencpu.com/products/16383/ex-blc-1146/EK_Monarch_Series_X4_Ram_Liquid_Cooling_Block_-_Acetal_CSQ_EK-RAM_Monarch_X4_-_Acetal_CSQ.html?tl=g30c225s557#blank
http://www.frozencpu.com/products/17755/ex-blc-1337/EK_RAM_Monarch_DIMM_Module_-_2_Pack_-_Black_EK-RAM_Monarch_Module_-_Black_2pcs.html?tl=g30c225s557#blank
TUBING - 1/2in ID x 3/4in OD thats what im planning on since the 900d is a huge case so bigger tubing will match it nicely I believe.
Also will get a 290x full block just have to decide first if I want 2 290x or just one.
Finally one 480 radiator on the bottom part of the case I was thinking about doing 2 480s one on the bottom one on top but I might do one 480 on the bottom and one 140 on the back and just fans on top.
This is as far as I got so far. Still researching and looking up different 900d builds to get ideas how I want this rig done. Im deff want good looks though hence why ima watercool the ram as well I like how it looks.
As for the fans I will probably use the corsair ones most likely the AF series for the case fans and SP for the radiators. I like the colored ring, Im going for a black and red theme.
Thanks for looking I know its alot to look over but thanks alot to everyone that does.
You have chosen some excellent parts. What is the purpose of the computer? In general I wouldn't recommend cooling the mother board. I would concentrate on the CPU & GPU. If you go much beyond that, you will have to do two loops.
huntsman
887
Ahh ok yeah Im still debating what I want water cooled. Well the computer is going to be for me but I always wanted to build one thats just badass looking :) I was just planning on getting the case and mobo and switching everything over which I did, but now I might as well watercool it especially with all this room in the case. hehe.
