Question Need Suggestions for External USB Ports
MasterYoda327
215
5
10,585
I plan to build a new gaming PC soon. I am looking for either a powered or unpowered external USB port that has at least USB 3.0 type A plugs (having a few USB Type-C plugs would be nice too) that is capable of handling external devices and peripherals such as external hard drives, webcams, studio microphones, keyboards, mice, and printers. I am looking for an external unit that is reliable, capable of handling tasks such as those mentioned, and, if possible, is under $100. I appreciate any recommendations that you may have.
Thanks.
Ralston18 is right, Let me expand on details. First, names. ALL USB newer systems now are called USB 3.2 Genn. Gen1 can handle data at up to 5 Gb/s, and is still sometimes called USB3 or USB3.0. You can use any USB3.2 cable and connector with that. Gen2 can do up to 10 Gb/s and really should be using Type C connectors and cables. If you use a cable with Type A connectors, it will work but may not deliver that max data rate. Gen2x2 can move data up to 20 Gb/s (much faster than most devices on the market) and you MUST use good cables with Type C connectors.
A standard USB 3.2 port is supposed to supply power up to 0.9 A per port. When you use a HUB to connect several devices to one host port, that Hub MUST have its own power supply module to provide that power to ALL its output ports without relying on power from the host. For the simple case, assume the Hub you consider has ONLY data ports, and none called "Charging Ports". So for max power use you need to count up all the output ports and multiply by 0.9 A per port to get total max amps. You almost never will find a Hub that comes with its power supply "brick" able to do that! That is because it is NOT normal to connect to EVERY port a device that uses the max allowed. Further, even when you have all ports connected, you almost never use all devices simultaneously. So as a rough "rule" you should have a power supply unit able to provide perhaps 70% of that huge max. SOMETIMES you get that by buying a Hub larger than you need (comes with a larger power module), and NOT using all the ports.
Next is confusing. Power output from the ports is at 5 VDC and max 0.9 A per port. But may Hubs come with a power module that outputs 12 VDC at specified max amps, and the Hub converts that. So the calculations have to be done in WATTS of power. Watts = Volts x Amps. For example, if the Hub has 7 ports that would need max 5 x 0.9 x 7 = 31.5 W. The power module needs to be able to sup[ply 12 VDC for 31.5 W, so that would be 2.625A, preferably about 3 A max.
IF your Hub ALSO includes "Charging Ports" that can supply more current for fast charging, add those power needs to that of the "regular" ports in deciding what the power module must do.
Be aware that most "Charging Ports" actually do NOT provide data transfer functions, too. But some DO both functions. So read the specs and instructions for any Hub carefully.
Check the specs of the computer USB 3.2 port you plan to use to connect to the Hub. Ideally it should be a USB 3.2 Gen2 port with a Type C socket, and the Hub also should be Gen2, and the cable you use to make the connection should be a good-quality one with Type C connectors. SOME Hubs come with cheap cables that do not perform to Gen2 speeds, so keep that in mind. The Hub should have several Type C sockets and some Type A for slower devices. The reason I say this is that your Hub must share the data transfer rate of its host port (10 Gb/s for Gen2) among all devices plugged into it. So several high-speed devices like hard drives or SSD's may be limited in their performance if the data rate of the Hub and its host port is low. I doubt you can get a Hub rated for Gen2x2 speed - I have not seen them on the market yet. Besides, your computer may not have such a port.
Thanks. I am nearing the completion of my research and selection of parts for my replacement gaming PC. I am considering purchasing a USB 3.0 expansion card, but I also wanted to see what external USB port options may be available if the motherboard and expansion card do not have a sufficient number of ports for my needs. On the motherboard, I plan to connect my studio mic (for YouTube content creation), webcam, external hard drive, external DAC (for music and PC gaming), and either my external DVD or Blu Ray drives (for ripping audio CDs). If the motherboard doesn't have enough ports left over, I will connect my keyboard, mouse, joystick, USB Flash Drive (if PC case doesn't have appropriate USB ports on the top or front) and PC remote control sensor to the USB expansion card and external USB port if necessary. I hope this helps clear things up.
OP, bear in mind this method I use. USB2 ports are much slower, but many devices like keyboard, mouse, mic, joystick, etc. do not need anything faster than that. So I always connect all that stuff to mobo USB2 ports and reserve the USB3.2 ports for items like HDD's and SSD's that need the speed. Now, on MANY newer mobos there ARE one or two USB2 headers, but NONE on the mobo's rear panel of sockets, so you can't access them or may not even realize they exist. But I got a simple bracket that mounts in a rear case unused PCIe cover strip slot that carries FOUR USB2 sockets like this
https://www.amazon.com/StarTech-com...740841381&sprefix=USB2+bracket,aps,126&sr=8-2
Note that any USB2 mobo header actually contains TWO USB2 ports, so the two cables from that adapter plate connect to two mobo headers to expose four ports on your case back. If your mobo has only one such header, you can get a comparable adapter plate with only two sockets and one cable.
