Need Suggestions for mid-range CPU and motherboard
gqchishti
4
Hi Guys! I need some help buying a mid range processor and a Motherboard (only).My budget is not that good so need some suggestions.
I have a 500watt PSU and a nVidia GTX 650 and a PC case 😀 (PLEASE NO SUGGESTIONS ABOUT GPU )
The thing is my budget is 140-150 $ and i need a Nice cpu and a comptiable motherboard.
This one is an excellent choice as well. The Athlon outperforms the Pentium that I picked and both can be overclocked a lot. The ASUS board that I picked is better quality than the Gigabyte though. It comes down to preference at this point.
PCPartPicker part list: http://pcpartpicker.com/p/LXpzFT
Price breakdown by merchant: http://pcpartpicker.com/p/LXpzFT/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor ($69.99 @ Amazon)
Motherboard: Asus B85M-G Micro ATX LGA1150 Motherboard ($83.98 @ SuperBiiz)
Total: $153.97
Generated by PCPartPicker 2014-07-29 04:29 EDT-0400
Well thanks! :) and btw tell me PSU upgrade is necessory? i have 500 watt PSU.
500W should be sufficient to run either set up that you chose with the GPU that you have. I would only upgrade the PSU if it is a low quality one.What brand/model is your PSU?
