Need tips for a Graphics card
Michael Shunsby
42
Hello my computer has the integrated amd radeon 7660D and i was wondering which GPU would be better than this one?
im looking to spend no more than $120
A good card to purchase would be the Radeon HD7750. It would run on the power supply that comes in your computer, and you would not have to upgrade it. Should be within the pricerange as well.
If I'm not mistaken but if you install an AMD card, won't they integrated graphics and the graphic card run in crossfire? I'm not 100% sure so someone please correct me if I'm wrong. But if they is the case then getting an AMD 7770 would be a good choice. Newegg has then for about $110 ($90 after MIR).
