Need tips for optimizing my PC
Jan 1, 2019
14
From the results I have from UserBenchmark, my PC performs way under compaired to other PC with the same components : https://www.userbenchmark.com/UserRun/13603025
Seems like I have a high CPU background and probably heating issue. I removed the thermal paste recently and ordered a new SSD. I may not have the best components for heavy games, but I just want to know how to improve the state of my pc to his best potential with what I have.
I play games like League of Legends, Fortnite, GTA 5, Runescape 3, Diablo 3 and they all loose fps frequently when I play them.
Any tips is appreciated. Thanks!
Sigh, another thread with Userbenchmark as the instigator :'( Did you bother reading this? Userbenchmark isn't even supposed to be a standard followed by anyone. They have vaguely mentioned what you could do but never explain why you're going through said numbers percentile.
Now, that being said, can you please list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor + resolution:
Links to the parts would help. How old is your PSU?
Thats what I tought at first before posting, first time using benchmark and I was kinda skeptical about all that. Thanks for confirming.
CPU: AMD FX-6300 Vishera 32nm Technology
Motherboard: ASUSTeK Computer INC. M5A78L-M/USB3 (AM3R2)
Ram: 8.00GB Single-Channel DDR3 @ 803MHz
SSD/HDD: 931GB Seagate ST1000DM003-1SB10C ATA Device (SATA )
GPU: G246HL (1920x1080@60Hz)
2047MB NVIDIA GeForce GTX 950 (ASUStek Computer Inc)
PSU: 500W
Chassis: Golden Field Twenty One
OS: Windows 10 Home 64-bit
Monitor + resolution: Acer 1920x1080
Thanks for the answer
