Before I get started here's my current rig:
Processor: Intel Core 2 Duo 3.0 ghz
Motherboard: Asus P5Q Pro
Ram: 2 Gigabytes of RAM (Kingston).
Graphics Card: Nvidia Geforce 9600gt.
Current Power Supply: Cooler master 460w extreme cooling.
The thing is my old power supply overheated and was damaged beyond repair so I had to go out and buy a new one, I bought the cooler master 460w extreme cooling psu.
I hook everything up and start the computer but it powers on for a split second and then goes off.
So I decided to mess around and during this I removed the 6 pin PCI - E connector from my graphics card and then powered on and everything seemed to work just fine.
And after reconnecting the 6 pin pci e connector I get the same issue, the pc powers on for a split second and goes off again.
Some side info : My power supply is more than enough to handle my PC so kindly do not suggest that I upgrade it.
P.S : The PCI-e connector on the new power supply has 6 rails, one on each pin but the previous power supply had 2 molex cables to a 6 pin PCI e connector and that one only had 5 rails, could it be possible that if I try the molex cables - 6 pin pci e connector on this power supply then my card would start ?
and is there any other way I can fix this ?
