Hi all. Unfortunately 2 hours ago my system went Down. Turned out my cpu air cooler had broken off some limps that holds it tight. Only replacement i could gain to the x58 1366 socket was a krakenx31 Water cooler. So i bourght that one. Now I have assembled it. However Í need help with the last cable. The usb cable from the krakenx31. Does it goes into the asus rampage ii extreme usb1112 slot? Or where should i connect this usb cable to? Hope anyone knows. A Picture with the marked slots I can use would be greatly apreciated aswell.
Thanks All.
Here is where I have connected the krakenx31 usb cable to:
http://i64.tinypic.com/2ypggo7.jpg
PS:
Hope anyone replies soon, as I connected it to the usb1112 slot and I am not sure if that will do.
Thanks All.
PS:
