Need video card for emachine el1352-07e for diablo 3 help
dycegamez
301
Can anyone help me out I'm trying to play diablo 3 on my pc and need a new video card for my emachine el1352-07e . It's a pretty slim pc do Im in dire need of help .thank you
following what ct161 said that you have to update the driver press on the power button and as soon as it lights up start hiting f12 rapidly. now click on run safe mode with networking. your computer will start. know uninstall your graphics drivers only. now it might ask you to restart so restart and go into safe mode again with networking. open your browser and download and install the drivers then restart your computer and make it start up in normal mode. see if that works. if it doesn't you will have to get a new psu like what ct161 said.
400 to around 600 watts that would be excellent. i really dont know any power supplies with 400 to 600 watts that are slim and can fit in the computer.
i really dont know of any slim power supplies. i guess youll have to move wvery part into a new and bigger computer case to make room for a big power supplie instead.
We cant just guess we need real information so we dont waste anymore money for nothing. I'll start searching right know.
I really don't know I could be wright I could be wrong maybe it will fit maybe it will not if you want to experiment buy and try to see if it fits like what ct1615 said
Also tell me if it worked.
i came to this post because i have the same problem. can you find me a graphics card that will run games like crysis 2 battle field 3 mw3 and at the same time uses watts less then the ati radeon 5570. also provide links if possible. Thank You.
ct1615 please reply as fast as fast as you can. i know the radeon 4350 is not that good for gaming but will it work on a 220 watt psu.
the links are right here and i dont want to spend a lot of money so which one should i buy the refurbished or the new.
New- http://www.newegg.com/Product/Product.aspx?Item=N82E16814127613
Refurbished- http://www.newegg.com/Product/Product.aspx?Item=N82E16814150592
will these cards work on a 220 watt psu
i have a 220 watt psu like you do and that is extremly small. if you want that to work youll have to buy the power supply that me and ct1615 stated in our messages.
can you please respond to my messages. will the radeon 4350 work on a 220 watt psu. many people on the internet said yes. is that true that the radeon 4350 works on 220 watt psu.
i also do not guarantee that this will work i am just following what ct1615 saids. he sounds really confident and you should try it out.
