NERO Photo Snap Viewer Problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.video,rec.photo.digital (More info?)
I got the very latest version of NERO and it also installed the Nero Photo
Snap Viewer.
When I go to Photos (digital) all in JPG format, and I click on them, NERO
always comes immediately to the front and says it cannot open that (or any
other) photos.
I totally am baffled because Irfan View or Photo Impression do open them.
How can I change it so that this NERO Viewer does not get involved? I have
over 900 photos and do not want to select each one and go to "open with" and
then select something else than NERO.
But - why would NERO even not open normal .jpg files?
Archived from groups: microsoft.public.windowsxp.video (More info?)
Right under Photo Snap in Nero StartSmart is the option for Nero ImageDrive.
Click that then disable the image drive. That should solve your issue.
> Snap Viewer.
> other) photos.
Hi, excuse if there's any broken English! Well, i have had the exact same problem. If you haven't solved it yet then you can;
Open snap viewer
From the File menu choose or click on Configure plug-ins...
Then from the dialog box click top button named as Register plug-in...
Locate C/Program Files/Nero../ Nero PhotoSnap
And click to register one by one which i did it like that..
Bye the way i use Vista Ult 64 so if you find anything unfamiliar then you can also figure out on Xp too. Hope it helps
