Hey guys!
So I recently saw a build where a guy used the guts of an old NES as the case for his PC. I've got a $500 bonus coming in a week or two and I happen to have an old NES lying around so I figured it was time to upgrade.
My gaming PC now is solid, but it's loud and not very portable. My work has LAN parties every month now and I'd like something cool to bring along with me.
I'm running a Radeon HD 6850 along with a Phenom X2 1090T in my current rig and it's just now starting to show its age. I'd like something powerful enough to run games like The Witcher 3 or Dying Light on high settings. It's been awhile since I built a PC so I'm not sure if I'm even in the right price range for something like that (hence why I'm asking you fine folks!
Approximate Purchase Date: Within the next couple months
Budget Range: $500-$600 (can be pushed upwards of $700 if it's worth it)
System Usage from Most to Least Important: Gaming, Daily Stuff, Media
Are you buying a monitor: No
Parts to Upgrade: N/A New Build
Do you need to buy OS: Yes (Maybe, I have to talk to a friend...)
Preferred Website(s) for Parts: Newegg.com, Amazon.com
Parts Preferences: Cheap and reliable? I'm so out of the loop on who has quality these days...
Overclocking: No
SLI or Crossfire: No. Although if I could do an AMD APU and Hybrid Crossfire for equal or better preformance than a CPU and discrete card and get out a bit cheaper, I'd be willing to do that.
Your Monitor Resolution: 1920x1080 preferably
Additional Comments: I'll be putting all the guts into a gutted NES. I have HDDs (SSDs and regular drives) so I won't need those. I also have all the peripherals (mouse, keyboard, headphones, etc.)
Also, if anyone has any advice for mounting the thing inside the case, I'd love to hear it
And Most Importantly, Why Are You Upgrading: I want a mobile gaming rig with some flair
These are the parts I was looking at right now...
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130852
Video Card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487133
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182169
Memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231659
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113372
Total Cost: $643.20 before shipping.
As always folks, thanks in advance!
Overclocking: No
Motherboard:
Video Card:
PSU:
Memory:
CPU:
