Network Adapter Problem
APGConnor
I recently purchased a laptop and when the laptop goes into sleep mode it disable all wireless connectivity and I am not able to enable the wireless adapter in order to connect to wifi again. I have looked online about the problem and have yet to find a solution, such as not letting the computer switch of the wireless adapter in power management tab.
Any help would be appreciated
(I know you've tried setting the power setting but double check you have these settings on or changed)
For power management, set it to "high performance". If that solves the problem, you need to go into the " advanced power settings" to locate the option
