So recently I got a new pc with high end parts, but there is one problem that is plaguing my new pc that I also had with my older pc and I am struggling to find out if the wireless adapter is the problem or not. Basically when I perform one task that uses a good bit of the internet other applications begin to suffer internet wise. When I try to stream, the stream lags for all the viewers and obs shows that it isn't using the bit rate I set it to, and any game that I try to play multiplayer in begins perform worse with connectivity to the point where I can't play the game in multiplayer, but the game plays fine frame wise, currently my biggest issue.
I have +30mbps download and 5mb/s upload speeds.
I am struggling to find out if the wireless network adapter is the problem or not. It is a
Linksys AE2500 Network Adapter; So it is fairly old.
