Network Help ADSL-Wireless Router
azerty1234
Commendable
Sep 16, 2016
4
Hi!
Good day! I am humbly asking for your help/comments/suggestions for my small problem.
Primary Objective: To be able to access my Local Network and my Video Surveillance System with remote view and playback (using the application installed in the computer) outside using DDNS.
Secondary Objectives: Network Optimizations, further suggestions, and etc.
Current Status:
1. Everything works fine locally. I have already configured DDNS but I can only access the device page of my ADSL modem. I was able to setup remote viewing of all of my surveillance cameras using TeamViewer (but I restricted it in "View" mode only so that it can be accessed by others without messing with the computer settings).
2. I use the TP-Link WDR4300 to control the QoS of my network since the other router offers only simple control over QoS and the ADSL Modem does not support QoS per client (and has a very "primitive" controls).
Here is my network setup:
ADSL Modem
Firmware: Stock Factory
IP Address: 192.168.1.1/24
Wi-Fi: No
DDNS Option: No
LAN Port 1: Connected to WAN Port of TP-Link WDR4300
LAN Ports 2-4: No Connection
TP-Link WDR4300 - Located at Ground Floor
Firmware: DD-WRT
Connection Type: Automatic Configuration - DHCP
DHCP Pool Size: 50
DHCP IP Address Range: 192.168.0.100 - 192.168.0.149
IP Address: 192.168.0.55/24
Wi-Fi: Yes (5GHz only)
DDNS Option: Yes
WAN Port: Connected to LAN Port 1 of ADSL Modem
LAN Port 1: Connected to LAN Port 4 of Linksys EA6900
Linksys EA6900 - Located at Second Floor
TP-Link WDR4300
Firmware: DD-WRT
Connection Type: Bridged
IP Address: 192.168.0.180/24
Wi-Fi: Yes (both bands)
DDNS Option: Yes
WAN Port: No connection
LAN Ports 1-3: No Connection
LAN Port 4: Connected to LAN Port 1 of TP-Link WDR4300
IP Camera 1 (con. via Wi-Fi)
IP address: 192.168.0.160/24 >> manually assigned
IP Camera 2 (con. via Wi-Fi)
IP address: 192.168.0.161/24 >> manually assigned
IP Camera 3 (con. via Wi-Fi)
IP address: 192.168.0.162/24 >> manually assigned
Video Recorder (Computer, con. via Wi-Fi)
IP address: 192.168.0.169/24 >> manually assigned
Viewing Port Number: 5150
Playback Port Number: 5160
Network Diagram
Any help will be highly appreciated! 😍
Thanks
.55 should be fine. looks like you are dealing with a port forwarding problem
and possibly double or triple NATing.
on the TP-link have you forwarded port 5150 and 5160 to .169
DSL modem should be in bridge mode
thanks for the reply!
any tips on how to port forward? I am having a hard time following the guides on the internet (plus I don't know if I am going to perform the port forwarding at the TP-Link router or at the ADSL Modem).
If I changed the mode of my ADSL Modem to BRIDGED mode, do I need to change to configuration of my cabling (WAN Port of TP-Link and LAN Port 1 of ADSL Modem)?
@gbb0330
Sir! Good day! I am proud to say that I was able to fix my problem. Just like you said, I was able to set my ADSL Modem to BRIDGED MODE and I restarted all of my routers, I am now getting a WAN IP address in TPLINK router.
EDIT: forgot to add, I was also able to successfully port forward!
thank you very much! :bounce:
