Network Help!!
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Trying to solve a problem for a new client. They had a 98 computer acting
as a file server. This computer crashed, so they replaced it with an xp
computer. They also purchased a new XP computer as a workstation. They
have dial-up for the Internet. The network was using 169..... addresses
for connection. Someone had set up their network for them. I assigned IP
addresses using 192.168.1.X for each workstation. The new xp computers can
see each other, connect to each other no problem.
The other two workstations on the network cannot ping the server or the
new xp computer. They can send packets, but not receive them. I checked
the cables and the NIC cards and they seem to be fine. One workstation was
upgraded from ME to XP, I am not sure of the history of the other
workstation, but it is also running XP.
According to them, all was well until the server crashed.
Also, when setting up the tcp/ip as static, and having dial-up for the
Internet, is their a certain way to set up the IP protocol in the network
settings?
Thanks for the help in advance!!
Candace Sparks
"Candace Sparks" <rsparks24@comcast.net> wrote in message
news:EJKdnfjUs_SK6zDfRVn-uw@comcast.com...
can
was
> settings?
> Candace Sparks
One-way pings are almost always caused by firewalls. Turn
them off during testing!
Firewalls are turned off.
"Pegasus (MVP)" <I.can@fly.com> wrote in message
news:OrGdfQBcFHA.1404@TK2MSFTNGP09.phx.gbl...
>> acting
>> IP
> can
> was
>> settings?
>> Candace Sparks
I won't dispute what you say but I have dealt with several
posts where the OP, after much searching, found out that
the firewalls were not really off. Some have a habit of
intercepting packets even when turned off. They need to be
uninstalled.
news:yt2dnf2I8fkQCDDfRVn-vw@comcast.com...
> >> acting
xp
They
addresses
> >> IP
> > can
the
checked
> > was
network
> >> settings?
> >> Candace Sparks
Thanks. I will check that out!!
news:OlSMfWCcFHA.2696@TK2MSFTNGP09.phx.gbl...
> uninstalled.
>> >> acting
> xp
> They
> addresses
>> >> assigned
>> >> IP
>> >> computers
>> > can
> the
> checked
>> >> workstation
>> > was
> network
>> >> settings?
>> >> Candace Sparks
