Network problems help
HLRrussell
I can not send or receive messages. I also can not call or receive calls from anyone. it has been like this for two days now. What do I do, it says they are fixing it but obviously it's not working
Ask them if you can go pick a new SIM card from one of their stores. You should insist that you really need to use your phone, otherwise they usually take it easy.
If your network connection is not configured properly or suffers a technical failure, you can also contact us if you are looking for a booster and repeater equipment at cost-effective cost then you can touch with our staffs and get a fast mobile network by our phone booster and repeater. " Quantel" know how much issues you have to trouble with while you are trying to handle the client from mobile. That's why we provides mobile networks provider system all the unpleasant materials as faster as we can.
Thanks !!
Quantel
