Never built a system before, first try..please take a look
Kolorean
160
Like the title says, I have never built a system before. I have my step father who works as a lead field guy for Unysis, so I have help putting it together.
I have idea if all this works together, or if I am forgetting anything, is this even compatable?
Qty. Product Description Savings Total Price
AMC VGA Male to Male External Monitor Cable Model CVG-6MM - OEM
Item #: N82E16812105801
Return Policy: Standard Return Policy
$1.99
ASUS 16X DVD±R DVD Burner with 12X DVD-RAM Write and LightScribe Black E-IDE/ATAPI Model DRW-1612BL-BK - OEM
Item #: N82E16827135141
$32.99
XCLIO Windtunnel Fully Black Finish 1.0 mm SECC Chassis ATX Full Tower Computer Case - Retail
Item #: N82E16811103011
$114.99
Western Digital Raptor WD740ADFD 74GB 10,000 RPM Serial ATA150 Hard Drive - OEM
Item #: N82E16822136033
Return Policy: Limited 30-Day Return Policy
$20.00 Mail-in Rebate
$159.99
Acer Gamers Line AL2051W Black/Silver 20" 8ms DVI Widescreen LCD Monitor - Retail
Item #: N82E16824009105
Return Policy: [LCD] Limited Non-Refundable 30-Day Return Policy
-$20.00 Instant
$289.99
$269.99
ASUS M2N-E SLI Socket AM2 NVIDIA nForce 500 SLI MCP ATX AMD Motherboard - Retail
Item #: N82E16813131096
$92.99
SAPPHIRE 100164UL Radeon X1650PRO 256MB GDDR3 PCI Express x16 Silent Cooling Video Card - Retail
Item #: N82E16814102077
$279.98
($139.99 each)
Eagle Tech Panther X GM620PC ATX12V / EPS12V 620W Power Supply - Retail
Item #: N82E16817193008
-$20.00 Instant
$109.99
$89.99
MASSCOOL FD08025S1M4 80mm Case Fan - Retail
Item #: N82E16835150007
-$0.20 Sale
$3.98
$3.58
($1.79 each)
* LSI LOGIC LSI00042-F PCI-X SATA II Controller Card - Retail
Item #: N82E16816118046
* AMD Athlon 64 X2 3800+(65W) Windsor 2.0GHz Socket AM2 Processor Model ADO3800CUBOX - Retail
Item #: N82E16819103733
Return Policy: Processors (CPUs) Return Policy
FORGOT TO MENTION I BOUGHT THIS MY MY CURRENT SYSTEM AND PLAN TO PUT THESE 2 1 GIG SIMMS IN MY NEW SYSTEM:
MEM 1G|CORSAIR CM72SD1024RLP-3200 R - Retail X 2
Okies
Right for starters it'll proberly be a good idea to find out what you plan on using the computer for and what your actual budget is. Few things I can think of the top of my head is why the VGA cable when you've bought a TFT Monitor with DVI output?
Another option is there any particular reason for going for AMD & ATI over Intel & Nvidia?
Why do you have a SATAII controller? (There is 6 (Six) Sata portsalreadt on the mobo?
BTW unless you really need the extra few seconds which doesn't justify the price get a few cheaper HDDS. Avoid the hype about raptors good drives
Basicly, I am clueless, my current system is 3 and 1/2 years old, and I bought it direct from ABS. I am looking for a gaming system, I play Vanguard currently, and it's a graphics monster. My current system with my FX-51 and 9800XT gets about 20FPS in the second to lowest setting, I want to run this game in high quality, mind numbing graphics.
Egad! Toss those 1650s. A single 1950Pro or XT, or a 8800GTS 320mb is a much better choice. Seeing as you want excellent graphics, that'd be the 8800GTS. If your budget allows, you could even go up to a GTS 640mb or GTX. Crossfire/SLi is only for use with the absolute best (8800GTX) otherwise it's better to get a single card. Faster and cheaper.
And I echo everything else Chris said.
Instead of the AMD board and CPU, you'd be better off with something like a Gigabyte 965P DS3 and Intel e6300 or e6600.
Oh, and that Corsair memory is DDR. You'd need DDR2. Some decent quality DDR2-533 if you will never ever overclock, or DDR2-667/800 if you'll think about overclocking sometime. Which I highly recommend, especially for the e6300.
Alright
Motherboard, Ive not to much knowledge about current trends so look a few up
CPU
Graphics card
PSU
HDD
Ok well there s a few recommendations. If you time take a read of these forums to learn more about computer parts lots of helpful and intelligent people on here.
Edit realised you need new memory
Memory Ive tried and tested quite good. But as I say read reviews / forums and learn :)
First of all whats your budget?
You would get better performance out of an Intel system.
And getting 2x any card is worse than getting one higher end card. You should get a X1950pro (about $180), X1950XT (about $215), or 8800GTS 320Mb ($300). What ever fits your budget.
My budget, is my poker money I have saved up..about 1600.00
I am going to try and start all over again and see if I can get something going. I would really welcome some systems put together here on the boards, or builds that someone else have used.
You wont get it from that system. Im playing vanguard also and I have it set to max...I do get like 35-50fps but when I hit a city i still lag a bunch. My system is a tad bit more beefy then the setup you propose : my setup
C2D E6600
2GB DDR2 800
eVGA Nvidia 8800GTX
Gigabyte 965P-DS3 Mobo
Western Digital 160GB Serail ATA 3.0GBs 16mb cash.
Came to about 1600. But like the other person said..you bought a VGA cable for a DVI monitor. Dump the 10k RPM hardrive my HD actually has faster seek times and slightly slower write times (you wont tell the difference) and only costs me $62. If you could specifiy a budget Id be more than happy to build you a nice rig on paper.
**edit just seen your budget. Let me work some magic and Ill have a solid build for ya.
Going on advice here (thanks alot for all the replys) here is what I have come up with so far:
$114.99
Western Digital Caviar SE WD1600JS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822144415
$52.99
-$20.00 Instant
$289.99
$269.99
Foxconn FV-N88SMCD2-ON GeForce 8800GTS 320MB GDDR3 PCI Express x16 HDCP Video Card - Retail
Item #: N82E16814186017
$15.00 Mail-in Rebate
$299.99
FSP Group (Fortron Source) AX450-PN, 12cm FAN, version 2.2, 2 SATA, PCI Express, 450W Power Supply - Retail
Item #: N82E16817104954
-$4.00 Instant
$53.99
$49.99
OCZ S.O.E 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model OCZ2SOE8002GK - Retail
Item #: N82E16820227120
$175.99
ASUS P5L-VM 1394 LGA 775 Intel 945G Micro ATX Intel Motherboard - Retail
Item #: N82E16813131046
$94.99
Intel Core 2 Duo E6300 Conroe 1.86GHz LGA 775 Processor Model BX80557E6300 - Retail
Item #: N82E16819115005
$184.00
Microsoft Windows XP Home Sp2b 1pk w/Upgrade Coupon for Vista - OEM
Item #: N82E16832116169
Return Policy: Software Return Policy
$89.99
-$0.20 Sale
$3.98
$3.58
($1.79 each)
Subtotal: $1,336.50
Calculate Shipping
Zip Code: GO
Shipping: $54.77
Redeem Gift Certificates
Claim Code:
Security Code:
Redeem
Gift Certificates: $0.00
Apply Promo Code
Promo Code: Apply
Promo Code: $0.00
This cart qualifies for No Payments for 6 Months with Newegg.com Preferred Account What's this?
Grand Total: $1,391.2
Its getting there. Gave it a quick glance as im running out the door. You probably want this hard drive 16MB cache.
hard drive
Look at a bigger power supply. Personally just built a core 2 duo with this supply. Love the modular cables. Needed the short cable option they offered as it was for Thermaltake Lanbox
Silverstone
or
I have this one for another rig.
Seasonic
Others will give you some other choices as well. Think Seasonic has a modular cable unit as well.
I'll check back later to see how your progressing. Good luck.
How do you like this, bigger harddrive, video card , powersupply and monitor plus faster ram all under your $1600 budget.
XCLIO Windtunnel $114.99
(your choice)
GIGABYTE GA-965P-DS3 LGA 775 Intel P965 $122.99
(Why did you choose a micro atx ?)
EVGA 640-P2-N821-AR GeForce 8800GTS 640MB $389.99
(The GTX is too much for your budget)
SILVERSTONE ST50EF-Plus ATX 12V 2.2 500W PSU $99.99
(strong PSU with great quality, the bigger silverstone 600 recommended above would be better)
Intel Core 2 Duo E4300 Allendale 1.8GHz LGA 775 $169.00
(saving money with less overclocking stress other parts)
G.SKILL(2 x 1GB) DDR2 SDRAM DDR2 800 (PC2 6400) CAS4 $184.99
(Cas 4 vs. Cas 5,but your choice is ok to save a little)
Western Digital Caviar SE16 WD3200KS 320GB 7200 RPM SATA 3.0Gb/s
(more Gigs per $ and also fast) $89.99
Acer AL2223Wd Black-Silver 22" 5ms DVI Widescreen LCD $289.99
(lower reaction time and bigger screen)
Microsoft Windows XP Media Center Edition 2005 SP2b w/Upgrade Coupon for Vista - OEM $109.99
(XP home only upgrades free to Vista Basic, XP Media upgrades free to Vista premium )
Scythe Ninja SCNJ-1100P 120mm CPU Cooling Fan $39.99
(Great heatsink that is also quiet. )
New Egg Subtotal: $1,611.91
Their is a $30 rebate on the video card that brings this under your $1600 budget.
I was going on the person's above parts he linked in, as I said, you could say your build is gold, and I would stake a claim, I just don't know enough to have an informed decision yet.
Back to see how you are making out. Looks like Fox put together a nice rig, but you need to ask yourself how comfortable you are with over clocking. The E4300 is extreamly easy to overclock as it has such a low FSB. So if you have never overclocked this would be an excellent chip to start with and many people on this forum can help you when the time comes. But if you are dead against overclocking then you can look at a faster chip for more money, then getting rid of the cpu cooler and lowering your GPU to the next step down, the 8800GTS 320mb. Which should keep you in budget.
Ok, another round of revisions, what about this build? Am I missing anything?
$32.99
$114.99
Western Digital Caviar RE WD1600YS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822136062
$62.99
-$20.00 Instant
$289.99
$269.99
$299.99
SILVERSTONE SST-ST60F ATX 600W Power Supply - Retail
Item #: N82E16817163109
-$10.00 Instant
$139.99
$129.99
$175.99
$93.99
$184.00
$89.99
-$0.20 Sale
$3.98
$3.58
($1.79 each)
Subtotal: $1,458.49
Calculate Shipping
Zip Code: GO
Shipping: $58.16
Claim Code:
Security Code:
Redeem
Apply Promo Code
Promo Code: Apply
Promo Code: $0.00
Grand Total: $1,516.65
Your spec shows a micro ATX board. Your case will take a full size atx board. Maybe look at this one.
Asus MB
Or do a little more research on boards a lot to choose from. But no sense going with a micro unless you are building with a SFF case.
Ok changed the MoBo..anything else I need to do?
$32.99
$114.99
$62.99
-$25.00 Instant
$289.99
$264.99
$299.99
-$10.00 Instant
$139.99
$129.99
$175.99
ASUS P5N-E SLI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
Item #: N82E16813131142
Return Policy: Limited Non-Refundable 30-Day Return Policy
-$10.00 Instant
$149.99
$139.99
$184.00
$89.99
-$0.20 Sale
$3.98
$3.58
($1.79 each)
Subtotal: $1,499.49
Calculate Shipping
Zip Code: GO
Shipping: $58.16
Claim Code:
Security Code:
Redeem
Apply Promo Code
Promo Code: Apply
Promo Code: $0.00
Grand Total: $1,557.65
Ok so you are looking good. The last item I need to comment on is the extra case fans you picked. Checked out your case at the manufacturers sight and it is stating room for 120mm fans front and rear. You choose 80mm. THey may fit as well but i would go for the 120mm as they move alot of air at lower rpm which means they will most likely be quieter then the 80 mm. I'm sure you can find them for same price or close enough.
One other thing to consider. The card you choose is bundled with
-Bundled3DGamePad
-BundledRestoreITv7.0andVirtualDriveProv10.0
Don't know much about those items. But you may consider this card from EVGA. It comes with a free game. Dark Massiah. Don't know much about the game either but EVGA game bundles are usually decent games. Cards are guarenteed for life and they have a good step up program.
EVGA 8800 GTS 320Mb
No the two side case fans which are included are 250mm fans! They are frikkin huge. The open spots for the optionals are for 120mm fans Front and rear.
Changed the Mobo out on some folks advice, how's it looking now?
$32.99
$114.99
$62.99
-$25.00 Instant
$289.99
$264.99
$299.99
-$10.00 Instant
$139.99
$129.99
$175.99
EVGA 122-CK-NF68-TR LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail
Item #: N82E16813188010
$219.99
$184.00
$89.99
-$0.20 Sale
$3.98
$3.58
($1.79 each)
Subtotal: $1,579.49
Calculate Shipping
Zip Code: GO
Shipping: $55.69
Claim Code:
Security Code:
Redeem
Apply Promo Code
Promo Code: Apply
Promo Code: $0.00
Grand Total: $1,635.18
