So I Built a pc and its a beast but I feel like its not performing as well as it could because of the case I have. all of the components are kinda cramped into the case so I want to get all of the parts to make a custom water cooling loop, as well as the case listed below.
But other then knowing That I need tubing, radiators, a pump, and fittings, I don't know much about water cooling so if you could help me pick out parts to make sure I got everything correct and of course all compatible, that'd be great!!
Thnx Everyone
Here Are My Current Specs:
Case: NZXT - NZXT - Phantom ATX Full Tower Case
Cpu: Intel - Core i7-6800K 3.4GHz 6-Core Processor
Gpu's in SLI: Two Asus - GeForce GTX 1080 8GB ROG STRIX's
Memory: G.Skill - Ripjaws V Series 16GB (4 x 4GB) DDR4-3466
Motherboard: MSI - X99A GAMING PRO CARBON ATX LGA2011-3
Power Supply: EVGA - SuperNOVA G2 750W 80+ Gold Certified
Storage: Kingston - SSDNow V300 Series 120GB 2.5" SSD
Seagate - Barracuda 2TB 3.5" 7200RPM HDD
Parts LINK: https://pcpartpicker.com/user/Jaydon382/saved/#view=txYr7P
Here Is the Parts I have found that I am currently looking into buying:
Case: Thermaltake Tower 900 Snow Edition Tempered Glass Fully Modular E-ATX Vertical
Super Tower Chassis CA-1H1-00F6WN-00
Cpu Water Block: EK-Supremacy EVO Elite Edition - Intel 2011-3
Radiators: Two EK-CoolStream CE 560 (Quad)
Gpu Water Blocks: Two EK-FC1080 GTX Strix - Nickel
Two EK-FC1080 GTX Strix Backplate - Black --> Optional???
Fan Controller: Thermaltake Commander F6 RGB LCD 6 Channel Single 5.25” Bay Fan
Controller AC-024-BN1NAN-A1
THAT IS ALL THAT I HAVE FOUND SO FAR
I am still looking for: Pump or Pumps, Rigid Tubing, Drain Valve, Fill Port???, Flow Indicator, Psu Shroud, Pass-Through-Ports???, Pump's, Reservoir's, Motherboard block???, Compression Fitting, coolant.
I think that is all I need right??
And I used this chart to plan out the parts so far:
I am not sure which metal to use for the build as well.
Hopefully I remembered everything!, If any of those parts that I am planning on buying is wrong or is a bad choice let me know. as well as, I still need help finding the rest of the components"above"
Please I have been needing help with this for a while and nobody is willing to help me or doesnt know what they are doing...
Thanks Again!!
Thnx Everyone
Thanks Again!!
