New Asus Monitor VG248QE goes grey static when I load skype and forces me to reboot
awakes
I recently bought this new screen it's 144hz. Prior to using this I was using my panasonic Plasma TV via HDMI cable. When I plugged in the Dual DVI cable to use the monitor everything worked EXCEPT for when I try and launch Skype my screen looks like this http://imgur.com/6XjKC8n (took picture with my cell phone).
I can't exit the screen and when I Control/Alt + Delete the screen goes blank and I have to restart the computer.
I did online tech support with Skype: they remote logged into my system and when I launched Skype it worked fine, but there was a minor screen flicker. I also uninstalled and reinstalled Skype. Once done with the IT help it continued to do it.
I talked to asus and hooked an HDMI from my tower to the monitor and it worked fine as well at 60 hz.
It's odd because this only occurs with Skype: I can launch google, origin, battlenet, play games, etc. But when I launch skype the screen goes nuts.
Any thoughts? Thanks.
Windows 7 -64 bit
AMD FX-8320 3.5GHz 8-Core Processor
Gigabyte GA-970A-D3P ATX AM3+/AM3 Motherboard
G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1600 Memory
XFX Radeon R9 280X 3GB Video Card
I have got the same card (XFX Radeon R9 280X Black Edition) and a 144Hz Monitor (AOC G2460P) and I'm having the same issue launching skype, if you have found a solution, please post it here
My friend has the same monitor at 144 hz and has no issues running skype. He has a nvidia card. We play BF4 at 144 hz and use skype to talk
