Hi folks,
Can I get some advice on a system that my son and I have just put together for video encoding/editing plz? We are by no means hardware techies.
Case: Fractal Define R6 (USB-C)
Motherboard: Asus Prime X570 Pro
CPU: AMD Ryzen 3900x (Stock Wraith Cooler)
RAM: 32Gb (4x8 Corsair Vengeance 3600Mhz- CMW16GX4M2C3600C18)
GFX Card: Asus GeForce GTX 1550 Super
PSU: Corsair HX570i
Have updated the BIOS from 1005 to current 1407, installed AMD chipset drivers and set AMD Ryzen High Performance in Windows power plans. Windows 10 LTSC.
CPU Temp: When under load during an x264 encode, the CPU Temp is hitting 94/95, which I understand is too hot for sustained periods? By disabling PBO in the BIOS it’s reduced to max 87/88. Do I need to decrease voltages or such like to bring temp down, increase case fan speeds to get more air in, etc? Is the stock Wraith Prim cooler sufficient? Obviously I'd like to try BIOS tweaks before any cooling upgrade. As an encoding machine it will obviously be under high loads.
CPU Auto Boost: Have very little understanding of it. Before disabling PBO I followed this video and mine didn’t boost? Has anyone got a link for non techies to try and understand it plz?
RAM: Chose RAM as it was on the Asus QVL. It shows in BIOS as 2133Mhz, when enabling D.O.C.P it shows in Ai Tweaker as 3600Mhz, is this correct, do I need to chage anything?
Two Screenshots: 1st = PBO enabled. 2nd = PBO disabled.
TIA.
Edit: Installed Ryzen Master software, didn't have a clue what any of it meant! Seen a couple of reviews saying it's become overly complex for non techies like me.
PSU: Corsair HX570i
TIA.
