Question New build advice ! Please help !
Noticed that you had chosen the white AIO cooler. So white themed build i guess?
If you want to spend a bit less:
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor (£349.98 @ Amazon UK)
CPU Cooler: Thermalright Peerless Assassin 120 White ARGB 66.17 CFM CPU Cooler (£45.85 @ Amazon UK)
Motherboard: Asus ROG STRIX B650-A GAMING WIFI ATX AM5 Motherboard (£185.99 @ Amazon UK)
Memory: ADATA XPG Lancer Blade 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£106.94 @ NeoComputers)
Storage: Silicon Power XS70 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£114.99 @ Amazon UK)
Video Card: Zotac GAMING Trinity OC GeForce RTX 4070 Ti SUPER 16 GB Video Card (£807.98 @ Overclockers.co.uk)
Case: Deepcool CH560 ATX Mid Tower Case (£79.98 @ Amazon UK)
Power Supply: Thermaltake Toughpower GF A3 Snow 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£135.46 @ Scan.co.uk)
Total: £1827.17
Generated by PCPartPicker 2024-02-13 19:54 GMT+0000
Legend ! yes full white. Is the motherboard I originally chose as good as this one ?
You simply mentioned ROG strix mobo. I dont know which model exactly.
Nevertheless, a B650 mobo with pcie 5.0 M.2 support is more than sufficient for general PC gamers. You would need the X670 or X670E version only if you need more pcie 5.0 lanes for expansion cards or more sata ports or other I/O.
Check the USB headers, ARGB headers, sata ports, front panel and back panel ports and decide for yourself if you need anything extra in the X670 board.
Thankyou bud ! I like the monitors but I need 240 Hz minimum so decided on the Samsung odyssey G7 unfortunately they are 27 inch but it's the best I can find ATM. I already have two mounted curved MSI monitors that are 24 but cannot find a 240 Hz 1440P monitor ANYWHERE ! it's a heartbreaker ! So my monitor aesthetic will be killed off lol
Just always used Nvidia buddy. Is that the sapphire 7900XT ? What makes it better ? Just want to know for performance. I've been told this card with the CPU I'm buying will do really well
the 7900xt does better in most games than the 4070 super and even beating out the 4070ti super with its 16gb of vram ..
The 7900xt has 20gb vram ..
just watched a video and the 7900xt is kicking the arse of the 4070 super and 4070 TI super in most cases ..
Rt is always a Nvidia win BUT anything under a 4080 4090 DLSS is required for any decent playable frame rates
AMD has FSR which while not as good as DLSS its still a decent up scaler
If you have always used Nvidia thats cool not issue for me but AMD beat Most of Nvidia's cards these days in raster at a cheaper price ..
Exclude the 4090 cause thats the best of the best
Reactions: rekenukhh
