Question New build, case fans and CPU fan runs, but nothing else does.
May 19, 2020
7
Hi there,
I recently finished building my PC, and I've run into a problem; when I turn it on, the case fans run, as does the CPU cooler fan, but it doesn't boot, and the graphics card doesn't run either.
My specs are:
mobo: Gigabyte X570 UD
cpu: AMD Ryzen 5 3600
gpu: RX 5700xt
650W PSU
I'm very much an amateur at building PCs, so I'm lost as to what I should do from here. Any help is appreciated, thanks.
Hi there,
My specs are:
gpu: RX 5700xt
650W PSU
Check every connection. Check for bent pins on CPU. Try each RAM stick individually. Clear cmos. After those steps let us know.
May 19, 2020
7
Hi, I've been trying to get my new PC working, and after taking out everything except the CPU and one stick of RAM, it still doesn't boot.
However when I do press the power button, and the fans start up, they run for a few moments before slowing and quieting down. Does this mean the CPU is working or is it unrelated? I don't think the CPU has any bent pins, so I don't know why it would not be booting. Any troubleshooting tips are appreciated, thanks.
