Approximate Purchase Date: This month
Budget Range: $2000-$4000
System Usage from Most to Least Important: Running 2-3 virtual machines, email, browsing, streaming. No gaming.
Are you buying a monitor: Yes, at least two.
Parts to Upgrade: CPU, mobo, Ram, SSD, fans, heatsink, psu, video, etc
Do you need to buy OS: No, Linux Mint, one of virtuals will have Win7Pro
Preferred Website(s) for Parts: Newegg
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: haven't decided yet
Additional Comments: Computer is used mainly for work (healthcare industry).
And Most Importantly, Why Are You Upgrading: well the computer I am currently using I built back in 2009. (High end parts at the time.) I figured it was time for an upgrade 😉
Parts Preferences:
Intel Xeon E5-2640 V4 Broadwell-EP 2.4 GHz 10 x 256KB L2 Cache 25MB L3 Cache LGA 2011-3 90W BX80660E52640V4 Server Processor
https://www.newegg.com/Product/Product.aspx?Item=N82E16819117631
ASRock X99 Taichi LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard
https://www.newegg.com/Product/Product.aspx?Item=N82E16813157719
G.SKILL Ripjaws 4 Series 64GB (8 x 8GB) 288-Pin DDR4 SDRAM DDR4 2133 (PC4 17000) Memory Kit Model F4-2133C15Q2-64GRR
https://www.newegg.com/Product/Product.aspx?Item=N82E16820231834
EVGA GeForce GTX 1080 FTW GAMING ACX 3.0, 08G-P4-6286-KR, 8GB GDDR5X, RGB LED, 10CM FAN, 10 Power Phases, Double BIOS, DX12 OSD Support (PXOC)
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487245
Seasonic PRIME Ultra 1000W 80+ Titanium Power Supply, Full Modular, 135mm FDB Fan w/Hybrid Fan Control, ATX12V & EPS12V, Power On Self Tester, SSR-1000TR
https://www.newegg.com/Product/Product.aspx?item=N82E16817151195
Noctua NH-D14 SE2011 140mm and 120mm SSO CPU Cooler
https://www.newegg.com/Product/Product.aspx?Item=9SIA9PV3Y62105
Overclocking: No
Parts Preferences:
