Question New build has random system freezing (monitor image freezes too) requiring power button shutoff ?
Dec 4, 2022
6
Hello, my first time posting so I'm sorry if my formatting is bad.
BUILD:
I7-13700k (I flashed the BIOS for it to work)
32GB Trident Z5 - DDR5 6000 (Also tried Corsair Vengeance 5000)
Gigabyte 4080 (Also tried GTX 1080 ti)
MPG Z690 Carbon Wifi (Also tried MPG Z690 EDGE DDR5)
1TB 990 M.2
2TB Crucial M.2
XH1000 Corsair PSU
Let me know if there's anything else I'm missing.
Context: After installing Windows and my drivers I started playing Warzone with some friends, after thirty minutes or so the computer crashed/hung/froze, I don’t know the correct term but the monitors had the last images on them still and I had to hold the power button to shut the machine down. Note: For most of my troubleshooting it would take multiple restarts for the computer to reboot to Windows properly. It would often power up, half the mobo lights come on (sometimes check DRAM LED) and I would need to hold the power to restart.
I initially swapped out my new GPU with the old one, but I would still crash after 30 minutes or so of light to heavy loads. From gaming, to work video meetings, to watching youtube videos.
I then reinstalled windows, and redownloaded Discord/COD… Twice. Still, it crashed.
I then swapped out the RAM with the ram in parenthesis above, but still ran into the same issue, though I was able to play for close to an hour.
I then swapped mobos (I started with the edge and bought the carbon to replace it) to no avail. Still crashed after 30 minutes or so.
At this point, I’ll probably try replacing the PSU and then the CPU but I figured I’d check here for any advice. Has anyone run into a similar issue and found success? Any thoughts are appreciated :)
I don't want to claim this forum thread, but one more update from me. Bought a brand new MB today, slotted in the CPU and... still freezes. Tried it with 1 stick of RAM - freezes. According to helper800's advice I thought that maybe my OS drive is bad, so I put a Windows 11 installer on a USB drive, started booting into it and... got a freeze. A few days ago I ran a 4 hour memtest on RAM, finished with 0 errors on all four sticks. I'm slowly losing it, frankly. This small CPU upgrade has now cost me $850 in one week. And the issue is still there. Last possible culprit - PSU. Going to spend another $200+ tomorrow on a new, more powerful one.
If the PSU doesn't solve the problem, I think there's only one possible order of things: my PSU have gone bad, took out my first MB when I loaded it with 250W of 13700kf, and after it has gone bad, it took out the second brand new MB. Either that, or I'm totally out of options. Already tried three GPUs, two CPUs, two MBs, two PSUs (the other one was a cheap 500W one, but it had the same freezing, so I'm really scared that it's not the real culprit), with and without PCIe raiser. It's like this system, that I used literally every day, is now holding a huge grudge against me.
Maybe the storage is the problem?
I mean, it certainly may help.
@Darkbreeze can you give us a sanity check here? Besides attention to details errors in the building process I cannot think of anything obvious.
My PSU was partially the culprit. With my old PSU I couldn't reliably use my PC even with old CPU, but now I have swapped the PSU for a new one and the system with old CPU works all right. The new CPU, however, is the second part of the problem, it freezes on Windows boot screen on both new and old MB. I'm going to visit a local repair shop to run a quick test on the CPU on a whole different config to be 100% sure that it IS bad after all.
Reactions: helper800
That is the easiest, albeit not free, way of getting something like this sorted. You and others seem to have some fairly unique issues. remember if you have a solution to your problems post back what it was!
Here with the final update. Turns out the CPU was indeed the main issue. Contacted the seller, he took it for an expertize and they found out that the processor is indeed not working properly. Now, I can't say for sure if it's defective from the factory or my old half dead PSU fried it (although it's unlikely, since my old CPU worked fine with old PSU after all the hassle began), but the seller was nice enough to accept the return. Got a 12900ks now, works like a charm. Big thanks to helper800 for giving a lot of small advices, they will be of great help to people who might come to this thread in the future.
As I said in the reply, I tried booting from USB, bypassing the storage devices, but that didn't stop the freezing, sadly. And overall, I believe Windows manages bad drives pretty well, I had an ancient HDD with 40% dead sectors and Windows could somehow run, but would BSOD frequently. In the cases from this thread, most people got total freezes, not even BSODs, so I highly doubt that someone here has issues with storage.
Let us know if you have any issues in the future related to the same thing. It was probably a defective CPU to begin with, they do some funky stuff.
hahah I just read this and after a 3 week stint of waiting for my pc repair shop to get back to me, it was indeed the CPU as well. I had a 13700k and it was faulty, swapped in two different cpus and stressed test, worked perfect for literally days. Getting a new CPU and praying 😛.
This has got to be the largest amount of people with faulty CPUs in one place I have ever seen.
Reactions: NathanGalvin808
We’ll unfortunately it turns out that was not my issue, two weeks after I replaced the cpu it started freezing again. This makes no sense to me and I have no idea what the problem is. Should I take it to an expert?
I don't understand how it is possible that replacing the CPU fixed the issue for a while. What temps do you have around the time of the problem? How are CPU temps in general?
It may not be exactly your issue, however, if you go through this list it will eliminate a lot of small things that can cause issues;
Temperatures so far have always stayed below 60c
Temperatures at the time of crash were around 23c
I went through the list and I’ve tested everything I can so far.
I think I’m going to take it to a professional repair place cause their isn’t much more I could test for on my own.
Agreed, if you have gone through that list, a professional repair shop may be the best bet to figuring out what is going on. I would recommend making your own Question thread on the Systems part of the forum. It may save you from having to go to a repair shop. I relent I am out of ideas for you.
Hey guys, i have same problem.
My rig -
4090 tuf oc - NO PCIE RISER
i9 12900ks (upgraded to 13900ks)
z690 strix d4 wifi
4x8gb gskill trident c18 4600 (running c14-14-14-28 3600 1.5v)
Gigabyte 256 gb (OS) -- 92%
2 x 1tb WD ssd -- 99%
1 x 2TB Firecuda 530 -- 100%
So i had this problem, random freeze while playing a game. Headphones stop working/ my usb mic also everything freezes - no blue screeen but only way is to power off PC.
Had this with 12900ks (bios update did not help) then i sold my cpu and got 13900ks having same thing.
I am suspecting it is either motherboard or memory OC ( i've tested memory before and it passed) so im kinda confused.
Any help is welcome! Ty!
My rig -
z690 strix d4 wifi
I would make your own post about your specific issue on the forums under the systems section. At a quick glance I would say to set RAM OC back to default and wait for the issue to return. If it does not return then you know that the RAM OC the issue, if it does return then you know that RAM likely had nothing to do with the issue. I would run CMD as admin and paste in the following line; "sfc /scannow" This command will check for any corruption within a certain part of windows. This can happen because of memory issues, or regular windows updates but encounters some issues.
