Hi, so I have a brand new build with literally all new components(will list below) -
AMD Ryzen 5 5600X
Noctua NH-AM4 chromax.Black CPU Cooler
RTX 3060 GIGABYTE Gaming OC 12GB(REV 2.0)
OLOy RAM DDR4 (2x8GB) 3200MHz CL16
WD_Black 1TB SN750 NVME SSD
WD_Black 2TB HDD 7200RPM
APEVIA ATX-PR800W 800W 80+Gold Power Supply
ASRock B450M/ac (REV 2.0)Motherboard
GIM PSU Cable Extension Kit (White)
All the components are brand new except for the motherboard which is about 2 months old only and I purchased from my friend.
Me and him have tried taking out the CMOS battery and waiting up to 10 minutes then put it back in - didn’t work
We tried holding the power button for 3,5,10 & 20+ seconds at a time
We tried all different RAM DIMM slots with 2 separate types of RAM
We tried 2 separate power supplies but will be sticking with the one I listed as the other one was only 500W
We tried the 2 different slots for the GPU on the motherboard
We tried both DisplayPorts on GPU & both HDMI slots on GPU as well
The ASUS 165hz gaming monitor I have is brand new just opened - Turns on and works fine & we tried the PC on another monitor too and doesn’t work on there as well
We also tried applying a new coat of thermal paste to the CPU and put the cooler back on too and that didn’t work (the temps are insanely cool as I have 5-6 fans including x2 140mm NZXT fans then 3 Cyberpower fans then the cpu cooler)
Everything is plugged in correctly and set in the motherboard firmly 1000%
I’m clueless now as to why it is saying no signal on multiple displays… If anyone can please HELP!!! thank you!
AMD Ryzen 5 5600X
