Long story with parts and such below, but the short story is this:
3-4 years ago I had built PCs. I have 4 working machines I built in the house presently. This is the first new build in 3-4 years and I have no video out on a known good monitor with a known good graphics card. The fans on the Graphics card won't even spin up in this motherboard, but when put into my other towers it runs just fine. Anyone have any idea what I missed?
Long Story:
Got the Intel Arc A750 as a present from a friend/coworker. Previously had an Nvidia GTX1070TI, so I put it in my old build and it ran -- but clearly wasn't happy with the extremely outdated CPU (AMD FX-8350). Graphics card did run, but clearly needed a newer CPU in order to work, needing "resizable Bar" or ReBar enabled. I'm using my known good power supply of 800 watts.
I thought I did my due diligence in ensuring everything was compatible. The RAM speed is the maximum the Mother Board allows before needing to overclock (5600). It is the maximum supported size for a single stick (32gb). The Motherboard supports the LGA1700 chipset the CPU uses, and it supports the generation of chip the CPU is. Website even says Motherboard is compatible with the specific GPU.
I'm dumbfounded at what the issue could be. I have never had this kind of issue when building a PC before except with the graphics card was faulty, and that isn't the case as it works when plugged into my old rig. I picked a "KF" CPU as I figured I wouldn't need the onboard video, as again I've never needed to use the onboard video in 11 years of using/building PCs. But now I feel like that extra $30 would help me figure out what's going on. Should I have gotten the K series instead of the KF?
What I've tried:
Parts: New
Mother Board: ASUS Prime B760-PLUS Intel B760(13th and 12th Gen) LGA1700 ATX https://www.newegg.com/asus-prime-b760-plus/p/N82E16813119648
RAM: Patriot Viper Elite 5 32GB 288-Pin PC RAM DDR5 5600 (PC5 44800) Desktop Memory Model PVER532G56C38W https://www.newegg.com/patriot-32gb/p/N82E16820225326 CPU: Intel Core i5-12600KF Desktop Processor 10 (6P+4E) Cores up to 4.9 GHz Unlocked LGA1700 600 Series Chipset 125W https://www.newegg.com/p/3C6-008J-001G8 (12th Gen, in case you're wondering)
Parts: Known Good
PSU: [[800w]] ATX-JP800W https://www.amazon.com/Apevia-ATX-JP800W-Certified-Supports-Crossfire/dp/B01IE09DXM?th=1
GPU: Intel Arc A750 Limited Edition 8GB PCI Express 4.0 Graphics Card 21P02J00BA https://www.newegg.com/intel-arc-a750-21p02j00ba/p/N82E16814883002
Long Story:
What I've tried:
- Tried a different known good GPU, same story.
- Tried putting it into the other PCI slot and the GPU won't spin up. (It's so weird that the fans on the GPU won't spin)
- Tried moving the RAM stick to different slots.
- Tried removing the M.2 and SATA III
- Double checked that the risers are in the proper locations
- Three of the risers do not have a screw holding the motherboard to them, but I doubt this is the issue. Didn't want to fully screw it down until I knew it was working.
- Tried reseating everything except the CPU
- Reseating the CPU
- Removing & reapplying thermal paste (in case of overspill)
- Checking the CPU orientation (arrow on bottom left of CPU and motherboard's arrow matched, so shouldn't be issue).
- A different CPU fan (one didn't come stock, but I couldn't imagine the after market one I got could be an issue).
Parts: New
Parts: Known Good
