[New Build] Need Help for Building New PC
jjlu926
39
Hey,
I need help to see if all these parts will work together and if I should change some of the parts. I live in the US (United States). Gaming>Recording>Internet Browsing. My Budget is $800.
Parts:
Windows 7 64 bit
COOLER MASTER Hyper 212 EVO 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM OEM
Seagate ST310005N1A1AS-RK 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
MSI Radeon HD 7770 GHz Edition 1GB 128-bit GDDR5
Sparkle 600w Power Supply
G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model F3-10600CL9D-8GBNT
COOLER MASTER HAF 912
ASUS Crosshair V Formula AM3+ AMD 990FX
AMD FX 4 Core CPU 3.6 Ghz
Approximate Purchase Date: Anytime probably by the end of the year
Budget Range: ~$836 After Rebate
Parts Preferences: AMD CPU and Mid tower case
Overclocking: Maybe
SLI or Crossfire:No
Additional Comments: Are all these parts compatible? Anyway to lower the price and still play games on high quality with good fps?
jjlu926
39
@redeemer
Im really in no rush right now and i understand that hardware and software will get better and cheaper overtime so i will change some parts around but i just wanted to know if right now this could handle most games nowadays.... (hopefully that made sense :p)
cranked
512
20
Even if you are overclocking, which you state "maybe", I wouldn't go liquid cooling. If you aren't overclocking, skip an aftermarket cooler altogether for the time being and put more money into your GPU.
The rest is fine, just make sure to post again when closer to building because, as you already realize, things change rather quickly in the pc world.
jjlu926
39
Thanks for the advise, for the GPU should I go with the GTX 560, GTX 570 or AMD Radeon 7770
Similar threads
