Question New Build - Noodling on Case and overall parts list....TIA!!
ddsalkin
12
Considering white(ish) build w/RBG in black case. I do a build every 8-10 years so here I am again. Would like some general feedback, any cautions or words of wisdom, and trying to find a decent case.
Purchasing Date: Now, prior build finally is having issues and decided it was time to update.
Budget: Leading edge, not bleeding edge
System Usage: I build for gaming since any work I do on this computer a gaming rig will be able to handle
Monitor: Samsung 32' Odyssey OLED G8 (G80SD) 4K UHD 240Hz ($968.59) - bought with corporate discount off Samsung site
OS: Windows 11 new
Parts list so far:
-Ryzen 7 7800x3d ($461.95) - Walmart
-Sapphire Nitro+ AMD Radeon RX 7900 XTX Vapor-X 24 Bg ($1,102.49) - Newegg
-Gigabyte B650 Aorus Elite AX ICE ($199.99) - Newegg
-Corsair Vengeance DDR5 32Bg (2x16) RGB (6000/CL30) ($148.83) - Amazon
-Samsung 990 Pro 2 Tb ($168.65) - bought with corporate discount off Samsung site
-Arctic Liquid Freezer III (depends on case decision...would like 360 if it fits)
-PSU - TBD thinking 1200/1300w to be safe
-Legacy parts from old comp: 5.25" HDD SATA, 5.25" optical drive, 120 Gb Corsair GForce SDD
Case:
-Ideally Black tower with USBc front port, and ability to hold 5.25" front facing optical and internal 5.25 HDD. Can sacrifice the front 5.25" optical in favor of an external if need be but still want to use the 5.25" internal HDD.
-Considering:
-Thermaltake Core v71 - problem is while it can handle 2 x 5.25" (including one front facing), no USBc in front/top and adding the front oprital prohibits the 3 fan liquid cooling option as the optical takes up that space on the top front of case
-MSI Pano P100 - No 5.25" support
-**Be Quiet Dark Base 901 or smaller (still trying to figure out if this works...looks like it might have a 5.25" mount hidden under a flap??)...this might be the choice, but still looking into it.
Thanks again!
Lutfij
You could've passed on your PCPartPicker listing, if you did it there.
Make sure the ram you're looking at has AMD's E.X.P.O advertised on it's product package or website.
The matter about cases is subjective to your work environment and your own choices with aesthetics. Fractal's Pop series comes to mind but I think that limits your radiator size/support.
Reactions: ddsalkin
logainofhades
Yea, I missed that Amazon seller rating. 🤦‍♂️ Seeing what is in stock, even Best Buy is better priced, than that walmart price you gave.
Do you happen to live near a Microcenter?
Also I see you mentioned a 5.25" HDD Sata. Are you sure you don't mean 3.5"? I cannot recall ever seeing a 5.25" SATA drive.
ddsalkin
12
Nah, not close. Fry's used to be pretty good but they closed. The HDD I assume is SATA since that's what I initially thought it was connected with but may have to dig in and pull it out to verify.
ddsalkin
12
I also believe 5.25" hard drives died off in the late 90's.
Ok, settled...and actually a bit relieved. Turns out it's a Hitachi Deskstar 2TB 3.5-Inch CoolSpin RPM SATA III 6Gbps 32 MB Cache Internal Hard Drive. Hmmm....so just solving for an optical drive that can be had as external if needed. That opens up some case possibilities.
Reactions: ddsalkin
swapped parts for better price and performance:
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($439.00 @ Walmart)
CPU Cooler: Thermalright Peerless Assassin 140 77.8 CFM CPU Cooler ($39.90 @ Amazon)
Motherboard: Gigabyte B650 AORUS ELITE AX ICE ATX AM5 Motherboard ($199.99 @ Amazon)
Memory: Silicon Power XPOWER Zenith Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($88.97 @ B&H)
Storage: Seagate FireCuda 530 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($129.99 @ Amazon)
Video Card: Zotac GAMING Trinity OC GeForce RTX 4080 SUPER 16 GB Video Card ($1069.99 @ Amazon)
Case: Phanteks XT PRO ULTRA ATX Mid Tower Case ($69.99 @ Newegg)
Power Supply: Thermaltake Toughpower GF A3 Snow 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($120.99 @ Amazon)
Operating System: Microsoft Windows 11 Pro OEM - DVD 64-bit ($146.18 @ B&H)
Monitor: Samsung Odyssey OLED G8 32.0" 3840 x 2160 240 Hz Monitor ($999.99 @ Amazon)
Total: $3304.99
Generated by PCPartPicker 2024-09-12 03:53 EDT-0400
Reactions: ddsalkin
