Everything in bios rn is set back to autoIs the frequency set to auto?
It looks like your motherboard should be able to support up to 4600 Mhz, the cpu limit might be causing the problem. What’s the max rated frequency for your ram?
The i7 11700k supports up to 3200 Mhz. After that you’re in overclocking territory, but it’s a bit strange that 3600 Mhz causes the pc to not boot. You can try manually setting the frequency to 3200 and go up in 100 intervals to see what happens.3600mhz
Ill lyk how it goes im doing the tests rn starting from 3200 that boots the system fineThe i7 11700k supports up to 3200 Mhz. After that you’re in overclocking territory, but it’s a bit strange that 3600 Mhz causes the pc to not boot. You can try manually setting the frequency to 3200 and go up in 100 intervals to see what happens.
