New build parts advice
richjb
8
APPROXIMATE PURCHASE DATE: 7-14 days
BUDGET RANGE: 1500-2000 Before / After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, internet, general home use
PARTS NOT REQUIRED: (keyboard, mouse, monitor, speakers)
PREFERRED WEBSITE(S) FOR PARTS: (e.g.: newegg.com, other trusted sites)
COUNTRY OF ORIGIN: (USA)
PARTS PREFERENCES: by brand or type (e.g.: I would like to use an Intel CPU & ASUS Mobo and full tower case)
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Yes / Maybe
MONITOR RESOLUTION: (re-use current monitor at this time)
ADDITIONAL COMMENTS: (e.g.: Need to have a window, I would like a quiet PC)
COOLER MASTER COSMOS S RC-1100-KKN1-GP Black Aluminum ATX Full Tower Computer Case http://www.newegg.com/Product/Product.aspx?Item=N82E16811119150
Western Digital VelociRaptor WD6000HLHX 600GB 10000 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822136555
EVGA 012-P3-1472-AR GeForce GTX 470 (Fermi) SuperClocked 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130549
COOLER MASTER GX Series RS750-ACAAE3-US 750W ATX12V v2.31 SLI Ready 80 PLUS BRONZE Certified Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817171053
CORSAIR DOMINATOR-GT 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model CMT6GX3M3A2000C8 http://www.newegg.com/Product/Product.aspx?Item=N82E16820145318
ASUS Rampage III Extreme LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Average Rating
4 out of 5 eggs4/5(90 reviews)
ROG, Support SLI/CrossFireX, SATA 6 Gb/s+ USB 3.0 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131642
Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor BX80601950 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
Comments:
I have never built nor do i know much about the process, but I am tired of spending ~ $2000 for pre-built moderate PC that is outdated in a couple of years and then need to get another.
I like nvdia, but not opposed to ATI if it get me the most bang for my $.
I did not include an optical drive, but need a CD/DVD burner type.
I did choose the Rampage III extreme - figuring it would be upgradable for a while. I am hopeful that this build would last a long time, while doing some upgrades over time. If this Mobo is too much and can get something almost as good for a little less I am open to that as well.
I have a spare internal HD for data storage
I was also looking at a cyberpower build that was pretty close to these specs (maybe a few less highend parts) for ~ $1800.
If I am missing any necessary components please let me know
Thanks in advance for any comments...
sp12
980
What resolution is your monitor? IMO you're buying some interesting parts...
No computer will be able to game on high for more than 2 years at most. IMO I would get an i5-760 build with a P55 mobo and upgrade in a year.
Specific components:
Raptor should be tossed for a Samsung f3+small SSD for the same price.
470 is expensive. http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007709&IsNodeId=1&bop=And&ActiveSearchResult=True&CompareItemList=48|14-162-049^14-162-049-TS%2C14-127-501^14-127-501-S01%2C14-125-320^14-125-320-TS
PSU is mediocre, XFX black edition 750 is the same price, nicer, high efficiency, and modular.
This ram kit is nicer and 100$ less. http://www.newegg.com/Product/Product.aspx?Item=N82E16820231335
A few things in your build arent good picks, either they are over priced or just arent good units.
The dominators are very expensive and memory is rarely a bottleneck, DDR3 2000MHz CL 8 will give you maybe 2% better performance than DDR3 1600MHz CL7 but will cost you about 80% more, i suggest the Gskill Pi Series instead, they are still very good, fast, but a lot cheaper too since you arent paying for the dominator name or the 2000MHz rated chips.
The 600GB raptor is a waste, for that price you can pick up a fast 1TB drive and a small SSD boot drive. Im not up to speed on SSDs, someone else can suggest a good one, but a 1TB Caviar black isnt going to be much slower than a 600GB Raptor but will cost a lot less
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533&cm_re=1tb_caviar_black-_-22-136-533-_-Product
Do NOT get a GX 750, it failed two reviews at jonnyguru so its now on my blacklist right next to a few raidmax units. After promo code and rebate the XFX 750W unit comes out to be cheaper and it is much better, 9.7/10 at jonnyguru, and its modular.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207003&Tpk=xfx%20750
The Superclocked GTX 470 isnt a very good deal, its quite a bit more than a basic GTX 470 and not a ton faster. You can pick up a 5870 combo'd with the XFX 750W unit for only slightly more than that GTX 470
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.492866
edit: im typing slow today
richjb
8
I dont have a very good monitor right now, but will upgrade it in the future (Hanns-G HW191D)
The issue I keep having is when I start with the mediocre computer I dont even start to game on high.
I am not sure about a SSD, a friend has gone through 2 of them.. not sure the exact problem... something like froze up and was unusable. With that being said I dont know anything about SSD's
Only a 19", then skip the raptor/SSD, just pick up the 1TB Caviar black and spend the extra $200 on a nice large monitor to exploit the power of the graphics card, i would keep the 19" around for dual screening, it works rather well, but a larger higher resolution monitor will make gaming more enjoyable.
richjb
8
I dont know much about it so I would be hesitant to do some OC'ing, but one I learn more about it would try it.
Mr Pizza
1,461
Hmm.. well if you aren't doing 4ghz eventually then the rampage iii is a waste,
richjb
8
Thanks.. that is a good idea, I can get this HD and a monitor. I can use my other internal HD for data, and the new for OS, programs etc...
In my current space I would not want to get bigger than ~ 24". What are some decent brands and basic specs I should look into?
richjb
8
I guess I am trying to get some high end parts to allow upgrading without a major rebuild. If there is another MB that has good potential for less $$ (rampage ii gene????)
The Rampage series is their highest end boards for overclocking, if you just want a good solid board a P6X58D Premium will be just as good except it will be missing some of the special OCing features that the Rampage has to make it a bit easier but you will still get the same performance and OC potential from it, and it costs almost $100 less
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
it can also combo with the 950 to save $15
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.495202
ASUS also makes some pretty nice monitors, this one is pretty close to the $200 range and is nice
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236095
richjb
8
Going back to not knowing much about building a PC... does anyone have any thoughts on a Falcon Northwest rig? I put one together using some "not so high end" components.
Chassis
Talon Standard
Black
Power Supply
750 Watt Modular
Motherboard
P7P55DE Pro
Processor
Core i5 760 2.80GHz
Processor Cooler
HeatSink/Fan
Processor Overclock
No Processor Overclock
Memory
4GB (2x2GB) 1333MHz DDR3
Video Card
Radeon 5770 (1GB)
Sound Card
OnBoard Audio
Networking
OnBoard
Ethernet
Hard Drive
1TB 7200RPM 6GB/s
Optical Drive
24x DVD Writer
Media Reader
Internal Media Reader
64Bit
Operating System
Warranty
1 Year Warranty Parts
and Service
$1366 plus S&H
I know most of you are the build it yourself type, but is this a decent deal? I can still purchase the new monitor and wont feel so bad if I upgrade in a year or two.
sp12
980
You could build that yourself for ~900$ or so.
It's pretty hard to kill an SSD. Did he set AHCI mode in bios? Is he using Windows 7? He may have been using an off brand.
I agree with everyone else here -- take some of that budget and get a nice monitor. IMO either an IPS or 120hz could be had in this budget. Monitors don't lose value like computer parts do.
richjb
8
Okay, I am close to settling on the following set up. What other parts am I missing to get this right (fans, etc.)?
LITE-ON Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Writer - Bulk - LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106333
A friend has this case and he loves it, any thoughts on this vs. another case?
NZXT Sentry-2 5.25" Touch Screen fan controller
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992005
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Asus ML238H 23" 1920 x 1080 2ms Full HD Swivel and Tilt adjustable LEDBacklight LCD Monitor Slim Design 250 cd/m2 10,000,000 :1
XFX Black Edition P1-750B-CAG9 750W ATX12V v2.2 / ESP12V v2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
G.SKILL PI Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7T-6GBPI
After rebate and combo deal this Mobo was only $80 more than the P6X58D
XFX HD-587X-ZNFV Radeon HD 5870 (Cypress XT) 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150490
Now the GPU is still something I am struggling with... the PSU & GPU was a combo deal until the GPU went out of stock this morning. I could still go either way on nvdia/ati, but dont know which MFG's to stay away from and which series is best for the money.
I could just buy this card somewhere else... like
http://www.portatech.com/catalog/viewitem.asp?id=27306&r=p
Total without GPU is $1557.00
GPU ~ $400.00
I would like to thank all who have commented thus far. I have never tried to do something like this, but after spending what feels like the last 50 hours reading posts/articles on TH and shopping I am starting to think its possible.
