Hi everyone,
I'm in the process of troubleshooting and trying to fix a persistent problem. I built a new PC this week, here are the specs (all new components)
ASUS RoG Strix B550-F (wifi)
Ryzen 7 5800x (watercooled with Lian Li Galahad 360)
Samsung M2 SSD 980
ASUS TUF GeForce RTX 3070
Corsair Vengeance 32gb (16x2) 3.2Mhz
Corsair RM 750 PSU
The problem:
When I turn off the PC/sleep and turn it on soon after it works without a problem. However, if I leave the PC off overnight, hitting the power button causes it to turn on for a split second before turning off (doesn't reach POST). If I unplug the PC from the main power supply and drain the capacitors it works. While the PC is on I do not have any issues.
What I have tried:
My next step is to replace out the motherboard but in the meantime I wanted to see if I could get some input whether I'm on the right track or not.
Thanks in advance!
Samsung M2 SSD 980
Corsair RM 750 PSU
The problem:
What I have tried:
- Making sure all connections are secure, including but not limited to PSU connections, GPU in mobo, and RAM being securely in place.
- Replacing PSU. I was trying to use my old PSU (CorsairHX850i) for this build but with this issue I wanted to see if the new PSU would solve the problem. With the old one, the PC would not turn in even immediately after I shut it down. With the new one, it only does this after longer periods of time.
- Updated BIOS and tried this at default settings and when turning off CPU fan monitoring (I read this setting could cause startup issues with water cooled systems)
Thanks in advance!
