Kit:
Gigabyte GA-Z68AP-D3 http://www.gigabyte.com/products/product-page.aspx?pid=3897#ov
Intel i7 2600K (using onboard graphics, not a discrete card)
Crucial C300 128gb SSD
8gb Kingston Value Ram
Windows7 Ultimate x64
System is running at standard speeds, not overclocked.
Main problems relate to:
Horrendous wake up times from sleep/hibernate
AHCI sata settings in Bios
Instability
I don't use this machine for gaming hence no graphics card and for the most part it's pleasingly fast but there are problems with it. The only 'tweaks' I have done are to allow all the cores/memory to be used when booting (through boot>advanced in msconfig), but the problems existed before that.
Firstly, this AHCI thing. Initially I did not realise this setting was necessary to get the full benefit of using a fast SSD as a boot disk and to enable the use of the TRIM function in Win7 so I had installed windows with it on the default of IDE, then found out about it afterwards. And also found that aside from a possible reg tweak to get round it, you can't change it once the OS is installed.
So I reinstalled the OS after enabling AHCI in the bios, expecting things to be slightly better all round. Not noticed any improvement I must admit but I have now got problems. When I plugged in the rest of my HDDs (normal Sata HDDs, not SSD like the boot drive) after getting the new OS up and running with AHCI enabled, it seems to go into a loop whereby I get the POST screen, then a message where I think the drivers install for AHCI (or something - sorry to be vague but the message is partly off screen and I cannot adjust it to see fully - only happens in AHCI mode though). Next it says "Loading operating system", then I hear a click from the piezo speaker and the pc reboots. It keeps on doing this loop.
So it seems as if AHCI does not like me having my other drives plugged in for some reason but as I understand it, having SSD boot and HDD additional drives is the most common setup people go for in general so this seems odd.
Second issue is that if I try to use Sleep mode, the machine won't resume. It just won't power up from the power on button.
To make it boot after putting it asleep I have to remove the power cord from the back then reinsert it and then boot.
I get the "Windows resume loader" screen then and it asks if I want to do a restore. Not sure about hibernate yet, although I notice after this failed sleep resume cycle that hibernate seems to have disappeared from the shutdown menu!
There is a gigabyte utility for quick boot which affects both the OS and the Bios somehow, and I have tried this set off and on but it doesn't seem to do much either way.
My laptop uses the same OS, is a much lower spec than this and resumes in 3 seconds, so why is it taking around a minute for this much more powerful machine to do the same?
I seem to recall a program that helps trace the boot process and show how long each bit takes, in order that causes of such problems can be investigated a bit better, but I can't recall the name. Boot something or other I think. Would that be worth trying, or would it not be suitable for a sleep cycle as opposed to reboot?
Third issue is crashes. I do a fair bit of video editing and often have many files open at the same time so when I build a machine this is one test that I like to do.
I've been trying this with between 6-10 small video files (mix of mpegs/avis), and they will play for a little while (a minute or two perhaps) then the machine freezes.
I've had task manager running when this happens and the cpu isnot even breaking a sweat when it crashes, and with tons of memory to spare, and also checked that cpu temperatures can be as low as 30C when it happens too.
That being the case I can't fathom why it would be doing this.
Sorry if any of these things are obvious or noobish stuff to you guys.
I've been building and fixing PCs for about 15 years now, but other than the odd bios setting and sometimes a bit of windows optimisation I don't usually tweak them that much in terms of performance once they're running satisfactorily. It's a while since I've built a new system so I'm a bit unfamiliar with some of the stuff I'm seeing in the bios on this new one.
Any help with these issues would be gratefully received thanks!
Instability
