New build problems. i need help!
Jul 6, 2018
5
I just upgraded my computer and clean installed windows 10
Just randomly my screen goes black, fans are still running, and i cant shut it down with power button, i have to kill the psu. i have tryed to fresh install all drivers. ran memtest, furmark, and prime95 with good results. so what the heck is wrong with my computer?
Ryzen 5 1600x
MSI gtx 1060 3GB
cm masterliquid 240
corsair rm 750w
G skill sniper x 3200mhz 8x2 ( with xmp )
asus rog strix b350 f gaming ( bios 3803 )
Samsung evo 840 250gb ssd
the problem is after i upgraded to ryzen, my computer screen randomly goes black, nothing shows up in eventviewer, i have to turn off my psu to shut it down. i have installed latest gpu and chipset drivers. pluss all the updates windows install for me. i got a little more stability by updating bios from 3803 to 4011, but i still get random blue screens ( kernel power 41 ) tryed to turn off xmp in bios, it did nothing.
it was a clean install yes, i just clean installed again just to be sure, but i still got the same issues. is it more then chipset, lan and gpu driver i need?
just looked at the QVL list, and my ram is not on there. is that the problem then? because its the same stability with or without xmp on. i just locked my cpu to 1.375 volt and 3.7ghz and its even more stable now then with default settings?? this ryzen build is really confusing me..
i did update the bios from 3803 to 4011, just ran 8+ hours of aida64 stability test, no error. giving constant volt to the cpu seems to have done the trick for now.
Never mind... it keeps crashing even more when multitasking
