New Build RAM Help, DRAM LED light flashing red, not porting to monito
jtylr123
21
Hello everyone, I need help with starting my computer and porting it onto my monitor. I have set up all the components in the case properly and is all running
I built a computer and its my first build.
The components are:
Asus p8z77-v lx motherboard
8gb Corsair Ram 2 x 4 GB DDR3
Intel core i5 3350p CPU
Sapphire Radeon HD 7850 2gb OC edition
Corsair 500w power supply
half a gb hdd western digi caviar blue
When I turn the Compter on it runs fine all fans working but does not post to the monitor, I am running it through a HDMi, all fans and components are running and mainly all looks good, The problem is that the DRAM LED light is flashing red, When i Hold the MemOk button for 3 seconds it turns the computer off. I have checked that the RAM is fully clipped in over 10 times and have took it out of the slots and back in.
I need help on what to do and how to fix this problems as I have ran out of ideas and the asus helpline was dreadful and blamed my monitor.
Thanks for any upcoming help I will be very grateful
jtylr123
21
there is 0610 on the motherboard, and i have tried it with one ram in one slot, nothing is working. Tomorrow I am going to take it all apart amd test each component. Im really stuck for ideas
