New build system fans won't work
Johnsmith1173
12
Okay so I made myself a computer and every time I try to plug in my system fans the computer won't turn on. I looked on the motherboard for the cables it is it wired the wrong way. Is there anything I can do it's causing my computer to become hot. Thanks
None of the fans will spin nothing turns on with the system when the system fans are plugged it. Btw 2 fans in the case. So nothing starts won't boot or anything when the system fans are in.
It is a three pin connector plugged into the motherboard and yes system boots fine with fans plugged in
