My problem is: i cant get my new setup to boot. I will describe everything i tried
My build
Motherboard: ASUS Z97 Pro wifi ac
Processor: i5 4690k
Memory: 2x8gb kingston hyperx 1866mhz
Cooler: zalman cnps 14x
GPU: Asus gtx 970 strix
HD: 3tb seagate
SSD: 250gb evo 850 samsung
PSU: EVGA supernova gs 650w
Case: R5 fractal
Basically whats happening:
My build wont boot, i get a error code A2 when there is any sata HD/SSD connected and a 99 when there is none. In both cases, the red light boot_device_led is on. The computer stays on, no beep sounds, but no video at all.
A brief summary:
3 days ago i assembled everything on my new build. When i tried to boot it, sometimes the boot happened and others dont. I was able to install windows and use it for 2 days, but when i turned off yesterday and tried to turn on i couldn't make it give any video.
Since in the motherboard manual says this red light is about the HD verificiation, i tried to boot with none connected. No sucess. I tried to boot around 20 times and i manage to get 1 video with 0 red lights on the board.
I took out the GPU and tried to boot on just with ram, CPU and cooler, with PSU on. No results.
I checked all power connections. With just CPU, motherboard, ram i should only need to connect 2 cables. The ATX 20/24 pins and the 8 pin power to CPU.
I checked if the motherboard was compatible with the i5 4690k. It was with all bios versions.
I took the motherboard out of the case i tried to turn it on. Same erros.
I took out the battery on the motherboard for couple minutes and tried boot again. No sucess.
Since it is a brand new motherboard, im thinking in sending back to the retailer (NCIX) for a fast replacement, but i want to try everything before doing so.
Any ideas of what is the problem?
My build
Processor: i5 4690k
HD: 3tb seagate
Case: R5 fractal
A brief summary:
